left door latch replacemet
The door latch mechanism is inside the body of the door frame, and somehow requires the interior panel to be removed, and then to take out the door latch electronic mechanism that is part of the door locking activation by the key fob.
Peter
Peter
Below is link to I believe the part you would need.
Click HERE to order or for more information
You definitely will have to remove the door card. You may need to remove the door channel too.
Jason
Unsure of replacement technique for door lock
I have bought a replacement door latch mechanism for my 08 TT convert. I'm not sure of the installation technique to install the new latch connected with the cable to the mounting bracket. Should I bolt the latch to the door before I attempt to install the mounting bracket to the door? It's rather a cumbersome handful with the springy cable attached. Any advise will be welcomed. I have a manual but the re-installation advice is sketchy to say the least.
ajg617
09-06-2015 07:23 AM
kjmiles
09-04-2015 04:01 AM
OSUNick
NorCal Discussion
09-02-2015 08:35 PM
