Reset Oil/Service Light - AudiWorld Forums
TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-2014
Old 04-11-2012, 07:24 AM   #1
Default Reset Oil/Service Light
Does the manual service light reset procedure for the MK1 work on the MK2? The reset procedure had you press & hold down the button on the right side of the rectangular digital display, turn on the ignition and when when "Service" displays, press the button on the left side of the display and turn off ignition.
Does anyone know if the light can be reset using an Actron OBDII scanner?
andydrummer is offline   Reply With Quote
Old 08-28-2012, 02:22 AM   #2
Default How do you reset service light indicator Audi TT
I fond a site where you can see the full procedure how to reset service light indicator Audi TT. If you like to reset any maintenance oil light after an oil change.
http://resetservicelight.com/reset-s...cator-audi-tt/
Or any warning light for service reminders which appears on the display.
Try and see if this work for you, for my Audi was working.
Piese Autoo is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
"Service Due" reset Cadx6 TT (Mk2) Discussion 24 12-15-2016 06:37 PM
First Experience with Audi Dealer Service Dept. the_duke A8 / S8 (D3 Platform) Discussion 6 09-10-2015 10:02 AM
Have misfire in cyl. 4 so i swapped icm's and now it won't start period. anticsAK A8 / S8 (D2 Platform) Discussion 0 09-06-2015 06:34 AM
No Start, Need Codes Diagnosis eggsngrits A8 / S8 (D3 Platform) Discussion 0 09-05-2015 11:22 AM
Have misfire in cyl. 4 so i swapped icm's and now it won't start period. anticsAK A8 / S8 (D2 Platform) Discussion 0 09-04-2015 10:59 PM
Tags
2012, a4, a5, audi, b5, b8, change, date, light, maintenance, oil, reset, s4, service, tt
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
