TT (Mk3) Discussion Discussion forum for the Mk3 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2014- present
Drive Select
Old 04-16-2016, 11:30 AM
i3adSaab's Avatar
Default Drive Select
Quick question.....when I set drive select to individual and I then have options on the quattro.....when I set the quattro to dynamic, is it moving power to the rear? If so, by how much?
Can't find anything in the manual to describe this.
thanks ahead....
Old 04-16-2016, 04:19 PM
adg44's Avatar
There is no pre-set torque split with the quattro system in the TT. It takes 150 readings every 10ms in order to determine the ideal torque split.
However, in dynamic mode, it will send more power to the rear in order to induce some oversteer and give you that more dynamic feeling.
Old 04-16-2016, 05:31 PM
i3adSaab's Avatar
ok thanks.....
Old 04-16-2016, 05:33 PM
Can_Quattro's Avatar
A video here you may find interesting:
https://www.audi-mediacenter.com/en/...-audi-tts-3870
And these:
Old 04-16-2016, 05:35 PM
Two of Three diagrams
Old 04-16-2016, 05:37 PM
Last one
Old 04-16-2016, 10:25 PM
superswiss's Avatar
Received 1,065 Likes on 740 Posts
The marketing material around the Haldex quattro system is very misleading. The Haldex system doesn't have a center differential, so it can't actually mechanically send more than 50% of the torque to the rear axle. It's just mechanically not possible. The Haldex clutch is on the rear axle and when it fully engages 50% goes to the front and 50% to the rear. In order to send more to the rear it would need a way to disengage the front axle, which it can't. So how can Audi claim up to a 100% can go the rear? Well, if the front axle has zero traction, then the rear axle does 100% of the work. Their marketing lingo doesn't differentiate between torque (force) and work (power). Drive Select in Dynamic engages the Haldex clutch more, so you are driving with a 50/50 split more often. It also steps up torque vectoring around corners to help rotate the car more and give you the impression that the rear is doing more work, whereas in the other modes the rear axle is only engaged more than 10% if the front loses traction and the torque vectoring is less aggressive.
Old 04-17-2016, 12:07 AM
x_man's Avatar
I wonder if just driving around in the suburbs would I ever use any other mode than AUTO?
Thanks X.
Old 04-17-2016, 03:04 AM
Huey52's Avatar
My most used modes, in the 'burbs:
Auto 70%
Auto with Sport mode 20%
Dynamic 8% (quiet country roads, such as early Sunday mornings)
Comfort 2% (wife aboard)
Initially I used Individual a lot but the above is more the norm these days.
Thanks X.
Bahn S4
10
09-23-2003 07:45 AM
JeepNTT
Audi allroad
08-27-2001 03:21 PM
Ed Kruszewski
10
08-29-1999 11:18 AM
Marius B
05-10-1999 11:10 AM
Quick Reply: Drive Select
