Headlights coming on while away from car
A couple times now, I've walked out to my car to find the headlights on. At first I was upset since I'd been away for a day and a half, and assumed they were draining battery the entire time, but everything seemed normal when I started up.
I'm pretty sure I read through the relevant features in the manual, so I'm aware that hitting the unlock button on the key would turn them on, and I thought maybe it was being pressed in my pocket as I walk out the door (my car and apartment are only separated by a thick cement wall). Tried to do it deliberately, but there's no way that signal is getting through.
Can you think of anything else that would cause this to happen? The last time it happened, as I approached, the lights went off and the car sounded like it just locked itself, so I'm thinking they lit up for some reason, and then timed out (after whatever the default is...15 seconds or so).
Anything to do with the AudiConnect phone app coming into range maybe? That doesn't really make sense though, since the car's wifi and 4g connections wouldn't even be active if the car is off, correct?
Hopefully it's something simple I've overlooked :\
Crap, I was secretly hoping I was just losing my mind, since it hasn't happened recently haha. I did get a "left &right dipped headlight malfunction" once the other night, despite them appearing to auto-level, and shine properly. It went away when I restarted the car, but maybe there really is something wrong with them, we'll see.
I did hear a sound like the car locked itself once as I approached. I don't think I hit the button in my pocket because there was no chirp and no lights flashing.
pbrown
A4 (B9 Platform) Discussion
10
10-26-2018 02:11 PM
PhilippZ
02-20-2008 07:29 PM
keman
02-11-2006 03:43 AM
