TT (Mk3) Discussion Discussion forum for the Mk3 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2014- present
Hill hold/assist
Old 07-26-2016, 10:11 AM
topgun77's Avatar
Default Hill hold/assist
I am finding the user manual a little difficult to understand. If you stopped on a hill, it says you put on the E-brake and when you step on the gas the E-brake releases automatically. This doesn't happen in my case.
Any suggestions?
Old 07-26-2016, 11:30 AM
n828cl's Avatar
The hill start assist does not require the driver to set the parking brake; that happens automatically when on a slope (the indicator in the switch does not illuminate). This prevents any rolling when moving your foot from the brake pedal to the accelerator.
While stopped with the engine running and not in neutral, you may set the parking brake to avoid having to hold the brake pedal down, thereby avoiding the risk of creeping forward (not a good thing to do to a DSG). The parking brake releases when you press the accelerator (not in neutral, door closed, seat belt on).
- Chuck
Old 07-26-2016, 12:04 PM
topgun77's Avatar
Default e-brake
- Chuck
Thanks Chuck for your suggestions. I did tried to put it in drive with the e-brakes on. When I stepped on the gas pedal, nothing happens and the e-brake did not release.
Old 07-26-2016, 12:05 PM
SYMAWD's Avatar
Door was shut and seat belt on?
Old 07-26-2016, 12:16 PM
n828cl's Avatar
I haven't tried shifting from N to D with the parking brake already on. What does work is setting the parking brake while in D (or S) and pushing on the brake pedal, then releasing the brake pedal, then pressing the accelerator - the typical sequence when at a stop light.
- Chuck
Old 07-26-2016, 03:58 PM
z06user's Avatar
The feature works, you'll notice it if you are at a light or stop sign on a steep incline. Instead of rolling back it will hold until you get on the gas.
Old 07-27-2016, 07:45 AM
topgun77's Avatar
Default Thank you
Thank you all for your reply. I will just try what you have suggested.
DennisMitchell
Audi A3 / S3 / RS 3 MKII
05-30-2015 11:45 AM
Jatmobil
A6 (C7 Platform) Discussion
08-01-2012 08:36 AM
2002ARki
30v V6 Discussion
12-30-2011 07:35 PM
revisiTTed
09-25-2008 08:39 AM
tusca
02-14-2005 03:09 PM
Quick Reply: Hill hold/assist
