My 2017 Audi TTS
#51
I did install it myself. its DIY friendly as long as u have the right tools. u need mainly torx screws for the belly pan below. having the car jacked up or on ramps helps a TON as you need space to remove the front belly pan to access one of the plugs. the rest is very easy.
#53
#54
Given the extra thickness of this stiffener and the slight droop of the transmission itself when detached I found it a bit hard to get the bolt again started, but once I got it, it was easy peezy. I too used drive-on ramps to afford enough room to drop the front of the belly pan and reach the work.
Excellent play-by-play: 034 Dogbone Insert 2016 TTS
#55
#56
Used nanoplex soap. Pretty good
Love adams interior cleaner
Chose guard and gloss over wax (:
Love vrt for tires
Tried to do the 034motorsport dogbone mount today. Unfortunately after taking apart the belly pan i realized it was the wrong one
Sucks it doesnt fit. Have to revisit this install
Love vrt for tires
#57
#58
Two (2)! Note: in the play-by-play original posting aaronz had the wrong number 1. Recommend you detail-review his well done posting.
034 Motorsport of course requests you to visually verify your OEM mount prior to ordering.
Great job detailing!! Given all the typical sand and salt of late really needed here in the NE and finally some decent weather to do so.
#59
Thanks! Weather has been phenomenal this weekend. Have the day off and gonna go take some pics!
#60
At the time I ordered mine I asked the rep to recommend the part number as I was too lazy to climb under, but he wisely wouldn't.
guess i shoulda asked i didnt know which version mine was and the rep suggested its ver 1 thinking its the same as the s3. But apparently not. Honest mistake i guess i woukda thought its the same as the s3 as well and not the golf. They sending me a new one so its find. Just loss of time yesterday.
