VAG-COM Discussion
Sponsored by:
Sponsored by:
2004 A8L Level Control Adaptation issues
Old 07-31-2014, 09:35 AM
Instanced's Avatar
Default 2004 A8L Level Control Adaptation issues
Hello,
I can try to explain this and hopefully someone knows what i'm talking about and knows the issue. Basically I tried to lower my A8L with Vag-Com (Air baby!) and it essentially threw up on itself and errored out (I'm to blame because I tried to lower it way lower then the max amount of... I think 25mm... I was going for 50mm)... Anyways I figured the best thing would be to put it back to stock height and go from there... So I followed the Ross Tech procedure for recalibrating the system and when I get to channel 05 (the save channel) it says its not available or invalid or something along those lines. so I can't save the new values and reset the system. Has anyone had this issue and was able to fix it? I logged it as well:
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0
Data version: 20140212
Adaptation Channel 005:
Stored value
ERROR:
Channel 05
Not
Available
So ya any help would be appreciated... I've tried another ross tech cable and 3 other laptops just to weed out any questions about the hardware.
vutekho
Q5/SQ5 MKI (8R) Discussion
03-29-2013 10:00 AM
awdinut
05-11-2012 06:06 AM
inline4
VAG-COM Discussion
10-26-2007 07:17 PM
Der Kimbo
18
11-19-2005 08:33 AM
liz
09-22-2002 06:37 PM
Quick Reply: 2004 A8L Level Control Adaptation issues
