VAG-COM Discussion
Sponsored by:
Sponsored by:
00604 code, seen this a lot but no definite results please help
Old 08-04-2014, 07:59 AM
porsches4ed (APR S3)'s Avatar
Default 00604 code, seen this a lot but no definite results please help
So I saw a few people had this code:
00604 potentiometer positioning motor for air flow flap (g113) 29-10 short to ground- intermittent
I can't find a definite result. I ran the hvac basic settings test on 001 and 000 like Uwe from rosstech suggested to someone else and it ran fine, cleared the code but AC still doesn't work and the code comes up again. I then found that these sensors need to be replaced located behind the glove box. Possible replacement parts1H0907543A or 1K0907543A)
1H0907543A - Caloric Feeler Sensor - ES#1359467 and
1K0907543A - Temperature Sensor - ES#2575456
Has anyone actually completed this? I'm going to order the parts and try it. All of the posts I found basically stop after what I have mentioned so I'm assuming that's how to fix it. I just bought a new AC system for the car and it worked fine for about a month. Took it back and they ran tests and told me the compressor is not getting a signal to turn on so it may be a relay or sensor. (Mr tire in Maryland by navy base) they don't have the equipment to fix that so they suggested an Audi specialist (I go to NGP in lorton). I will drop it off there tomorrow but I kinda wanted to try and see if changing these sensors myself n saving some $ would work first. The compressor has lifetime warr and there's 2 year labor warr. Mr tire said if they say that needs to b changed they will do it at no charge. Is there a separate AC control unit for this??
Thanks for any help in advance.
Old 08-05-2014, 09:32 AM
jakematic's Avatar
Nothing else showing up in the Auto-Scan besides the 00604 ?
I'm guessing this is on the 2002 TT in your signature since there is no scan to review.
I would check the wiring diagram to see what other items share the same tracks as the G113.
If there is nothing else and the harness isn't faulty, then replace G113.
Otherwise find and correct the short in the harness or replace other faulty components.
gmanw54
08-02-2023 04:35 PM
Bob 2KS4
10-18-2022 11:16 PM
LGx
Audi A3 / S3 / RS 3
04-03-2018 03:57 AM
sbrimlow
VAG-COM Discussion
02-15-2010 04:12 PM
Quick Reply: 00604 code, seen this a lot but no definite results please help
