VAG-COM Discussion
Sponsored by:
Sponsored by:
00858 - Connection: Radio ZF Output to Antenna Amplifier
Old 09-22-2003, 04:08 PM
rotto
Guest
Posts: n/a
Default 00858 - Connection: Radio ZF Output to Antenna Amplifier
I found this fault code waiting for me today (full text included at end). Does any one have more insight into what this condition from the Radio is? I have cleared the code and am waiting to see if it comes back.
Address 56 -------------------------------------------------------
Controller: 8E0 035 195 A
Component: symphony II NP2 0050
Coding: 00201
Shop #: WSC 00000
1 Faults Found:
44-10 - Short Circuit - Intermittent
Old 09-22-2003, 05:29 PM
rotto
Guest
Posts: n/a
Default HF and ZF
OK. So in radio terms (English to German):
Radio frequency (RF) = Hochfrequenz (HF)
IF Alignment = ZF Abgleich
I then looked in my Bentley manual and see that there is a "Control unit for antenna selection, Underneath the roof frame trim" on my car and in the diagram it has HF and ZF marked on it. I can't be certain but I am guessing the ZF is NOT a signal return cable but a power output cable for the controller. The Bentley manual mentions "...the original Audi radio units have a remotely driven antenna (the voltage supply of the antenna amplifier is driven via a center wire of the high frequency cable)."
So does this error mean that the power supply cable to the antenna control has shorted? Or is this something else?
Old 10-01-2003, 05:40 AM
New Member
Manity's Avatar
Default Do you have an RF device?
I got this code After i install XM Radio RF module. But after i installed an amplified one it went away but i still have another code for the radio.
Manity
2002 2.7T
Old 10-02-2003, 01:20 PM
rotto
Guest
Posts: n/a
Default Nope, no XM, no mods... got this info...
...from the Bentley forum:
Check the antenna at the top of the rear window they are having an issue with board cracking at the hf/zf connections.
Looks like it will be time for yet another dealer visit... grumble grumble.
Richard Logiovino
05-15-2017 03:50 PM
Casablanca Avant
10-03-2007 06:00 AM
converge
Audi A3 / S3 / RS 3
08-05-2005 02:30 PM
audifirst
05-20-2001 02:29 PM
Tom A.
12-26-1999 03:34 PM
Quick Reply: 00858 - Connection: Radio ZF Output to Antenna Amplifier
