VAG-COM Discussion
Sponsored by:
Sponsored by:
06 A3 w/RNS-E and BT - need your VAG-COM codes!
Old 05-10-2006, 02:43 PM
  #11
Junior Member
avincar's Avatar
Did not - where do I check this?
Old 05-11-2006, 07:16 AM
  #12
Junior Member
avincar's Avatar
Where do I check MVB 141 field 4?
Old 05-11-2006, 10:59 AM
  #13
Theresias's Avatar
VAG-COM > Select > 19 - CAN-Gateway > Meas. Block - 08 > Meas. Block 141 Field 4
Old 05-11-2006, 01:21 PM
  #14
Junior Member
avincar's Avatar
4th Field - "Telephone 1" - "Telephone Electronics"
Old 05-11-2006, 02:04 PM
  #15
Junior Member
avincar's Avatar
Default So CAN Gateway "sees" BT, K-line sees it, why doesn't it show up?
We have looked also with a laptop with a BT dongle... sees our Moto RAZR OK. We can't "see" the BT module with the RAZR OR my Blackberry 7135e.
Old 05-11-2006, 02:16 PM
  #16
Theresias's Avatar
Default Email me directly...
...include a complete Auto-Scan of the car.
...include the values of the BT module adaptation channels 125-139.
Old 05-11-2006, 02:39 PM
  #17
Junior Member
avincar's Avatar
Info sent - did you receive OK?
Old 05-12-2006, 09:43 AM
  #18
Junior Member
avincar's Avatar
Default Detailed info:
SCAN:
The codes were cleared before running this test so the BT module having been removed and reinstalled should not have any impact on these codes.
I see that the Steering Wheel 16, the RNS-E 37/Radio 56, and the CAN Gateway 19 each had the same fault found - 01303 - Telephone (R36) 004 No Signal/Communication Intermittent.
The steering wheel is an 8P0 953 549 F and the coding is 0013142.
The nav/radio also shows 02005 - Coding Pin 004 No signal/communication. Does not say "intermittent" at all.
ADAPTATION VALUES:
Many adaptation channels showed Error - Not Available.
125 E
126 E
127 E
128 NA - 0
129 NA - 6
130 NA - 3
131 NA - 0
132 E
133 NA - 1
134 NA - 0
135 NA - 1234
136 NA - 5
137 E
138 E
139 E
Old 05-12-2006, 01:04 PM
  #19
Junior Member
avincar's Avatar
Any response from anyone? Help appreciated...
Old 05-14-2006, 12:32 AM
  #20
Theresias's Avatar
Default Havn't been able to reply earlier, sorry.
Since you retrofitted the nav, where did you get the wiring from? Seems that there is a wiring issue too.
The data you send looks ok, nothing bad about that. Still an Auto-Scan would be helpful to get some more details about the modules themselves.
Quick Reply: 06 A3 w/RNS-E and BT - need your VAG-COM codes!
