07 Audi A6 check engine light! HeLp DeCoDe!
Hello,
I am new to my A6 ~ 2 months. I paid a local to run a scan on my 2007 Audi A6 3.2L Quattro. I have replaced the Manifold Absolute Pressure (MAP) sensor already. Please help deciding my next step. Car seems to run fine.
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 65 72 77
VIN: WAUEH74F77N006636 Mileage: 164080km-101954miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F2 910 559 HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0020
Revision: --H19--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 02325 785 00200
VCID: 69D22BFA403FE7095E-803C
7 Faults Found:
004440 - Manifold Pressure Sensor (G71)
P1158 - 009 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 248
Reset counter: 29
Mileage: 150935 km
Time Indication: 0
Date: 2016.04.17
Time: 13:18:39
Freeze Frame:
RPM: 672 /min
Mass Air / Rev.: 179.9 mg/str
Temperature: 90.0∞C
Idle
Voltage: 13.57 V
Speed: 0.0 km/h
000104 - MAP/MAF <-> Throttle Position Correlation
P0068 - 007 - - Intermittent
Freeze Frame:
Fault Priority: 2
Reset counter: 29
Mileage: 150935 km
Time Indication: 0
Date: 2016.04.17
Time: 13:18:39
008304 - Intake Manifold Tuning Valve (Bank 1)
P2070 - 006 - Stuck Open
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 117
Reset counter: 40
Mileage: 161626 km
Time Indication: 0
Date: 2017.01.19
Time: 02:05:51
Freeze Frame:
RPM: 768 /min
Mass Air / Rev.: 190.8 mg/str
Temperature: 51.0∞C
Idle
Absolute Pres.: 478.8 mbar
Speed: 0.0 km/h
008198 - Intake Manifold Flap; Bank 1
P2006 - 006 - Stuck Closed - MIL ON
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Mileage: 161626 km
Time Indication: 0
Date: 2017.01.19
Time: 02:05:51
008199 - Intake Manifold Flap; Bank 2
P2007 - 006 - Stuck Closed - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 4
Fault Frequency: 66
Reset counter: 40
Mileage: 161626 km
Time Indication: 0
Date: 2017.01.19
Time: 02:08:26
Freeze Frame:
RPM: 2336 /min
Mass Air / Rev.: 370.6 mg/str
Temperature: 61.5∞C
Part Throttle
Voltage: 1.220 V
Speed: 30.0 km/h
004438 - Manifold Pressure Sensor (G71)
P1156 - 007 - Open/Short to Ground - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 66
Reset counter: 40
Mileage: 161626 km
Time Indication: 0
Date: 2017.01.19
Time: 02:08:26
009220 - EVAP Leak Detection Pump Sense Circuit
P2404 - 006 - Implausible Signal - MIL ON
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 40
Mileage: 163807 km
Time Indication: 0
Date: 2017.02.23
Time: 11:07:19
Freeze Frame:
RPM: 1440 /min
Mass Air / Rev.: 261.6 mg/str
Temperature: 15.0∞C
Part Throttle
Voltage: 13.67 V
Speed: 16.0 km/h
Readiness: 0000 0000
7 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 29
Mileage: 150935 km
Time Indication: 0
Date: 2016.04.17
Time: 13:18:39
Freeze Frame:
RPM: 672 /min
Temperature: 90.0∞C
Idle
Voltage: 13.57 V
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Reset counter: 29
Mileage: 150935 km
Time Indication: 0
Date: 2016.04.17
Time: 13:18:39
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Mileage: 161626 km
Time Indication: 0
Date: 2017.01.19
Time: 02:05:51
Freeze Frame:
RPM: 768 /min
Temperature: 51.0∞C
Idle
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Reset counter: 40
Mileage: 161626 km
Time Indication: 0
Date: 2017.01.19
Time: 02:05:51
Freeze Frame:
Fault Priority: 4
Fault Frequency: 66
Reset counter: 40
Mileage: 161626 km
Time Indication: 0
Date: 2017.01.19
Time: 02:08:26
Freeze Frame:
RPM: 2336 /min
Temperature: 61.5∞C
Part Throttle
Voltage: 1.220 V
Speed: 30.0 km/h
Freeze Frame:
Fault Priority: 4
Fault Frequency: 66
Reset counter: 40
Mileage: 161626 km
Time Indication: 0
Date: 2017.01.19
Time: 02:08:26
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 40
Mileage: 163807 km
Time Indication: 0
Date: 2017.02.23
Time: 11:07:19
Freeze Frame:
RPM: 1440 /min
Temperature: 15.0∞C
Part Throttle
Voltage: 13.67 V
Speed: 16.0 km/h
