'07 Q7 4.2 - Cluster Backlight Coding Issue
So I have noticed that it needs to get darker than usual for my automatic headlights to come on. I changed the coding to support +60% earlier today. We will see how that goes. My issue is I cannot code my cluster to have the gauges and needles ON all the time. Currently only the needles will light until the headlights come on. Current coding for my cluster is: 2641268. According to the VCDS the first bit '8' isn't even an option. I changed it to 3 to match the VCDS wiki, with no change. Then I looked into the A8 options to see if 8 actually was correct and the wiki was wrong. The 8 is an option under 'LIGHTING II' for gauges and needles on, however only my needles are on. I want me needles and gauges on all the time. Can someone help me out? Thanks!
Illumination II is MY specific for 4E.
Which label file in the Auto-Scan output is VCDS using 4L0-910 or 4L0-920 ?
If it does conform to Illumination II, I would try 9 instead of 8.
carl viking
36
04-27-2020 01:17 PM
