12 Hour Clock
12 Hour Clock
Just got my vag com and I am trying to sort things out on a US import 2003 S8 (chassis code 4D).
When the dealer installed DRL, they switched the instrument cluster display to kilometers and the clock now reads in 24 hour format.
I could not find any S8/A8 specific information but read posts on A4,A6 coding.
The current soft coding for the instrument cluster is 02383. Changing the third digit to a 4 will change the display from km to mi, and changing it to a 1 momentarily changed the clock to 12 hour format then it reverted to 24 hour mode.
Any ideas?
Where can I find a listing of what the coding values mean for the A8/S8? The Vag Wiki for these models is pretty sparse (nothing for intrument coding) or is this just a feature of vag com I havent discovered yet?
I am using a Hex USB and here is the Auto Scan
VAG-COM Version: Release 704.1
Data version: 20071016
Wednesday,04,June,2008,17:55:06:00883
Chassis Type: 4D - Audi A8 D2
Scan: 01 03 08 11 15 16 17 18 25 35 37 45 55 56 57 65 67 75 76 77
02
VIN: WAUGU44D73N002159
Address 01: Engine Labels: None
Part No: 4D0 907 560 CM
Component: 4.2L V8/5V G 0001
Coding: 06753
Shop #: WSC 02313
WAUGU44D73N002159 AUZ7Z0B2123572
No fault code found.
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 4D0-907-389-E.LBL
Part No: 4D0 907 389 E
Component: ABS/ESP allrad D57
Coding: 08397
Shop #: WSC 02313
Address 08: Auto HVAC Labels: 4D0-820-043-Q.LBL
Part No: 4D0 820 043 Q
Component: A8-Klimavollautomat D13
Coding: 00180
Shop #: WSC 02313
Address 15: Airbags Labels: 4D0-959-655-AI8.LBL
Part No: 4D0 959 655 T
Component: Airbag Front+Kopf 5001
Coding: 00417
Shop #: WSC 02313
Address 16: Steering wheel Labels: 4B0-907-487.LBL
Part No: 4B0 907 487 H
Component: Lenkradelektronik D01
Coding: 01015
Shop #: WSC 02313
Address 17: Instruments Labels: None
Part No: 4D0 919 035 AT
Component: KOMBI+WEGFAHRS.VDO D42
Coding: 02383
Shop #: WSC 91449
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 25: Immobilizer Labels: None
Part No: Bitte Adress
Component: e 17 eingeben
No Faults Found
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Part No: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16173
Shop #: WSC 23320
Address 37: Navigation Labels: None
Part No: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0008
Address 45: Inter. Monitor Labels: 4D0-951-177-B.LBL
Part No: 4D0 951 177 B
Component: Innenraumueberw. D06
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range Labels: 4Z7-907-357.LBL
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00001
Shop #: WSC 00000
Address 56: Radio Labels: None
Part No: 4D0 035 195 J
Component: symphony II NP2 0050
Coding: 00265
Shop #: WSC 02313
Address 65: Tire Pressure Labels: 4D0-907-273.LBL
Part No: 4D0 907 273 A
Component: Reifendruckueberw. D110
Coding: 22119
Shop #: WSC 02313
Address 75: Telematics Labels: None
Part No SW: 8E0 035 616 HW: 8E0 035 616
Component: Telematik USA1
Coding: 0003333
Shop #: WSC 08213
Address 76: Park Assist Labels: 4D0-919-283.LBL
Part No: 4D0 919 283
Component: Parkingsystem A8 RDW D07
Coding: 01108
Shop #: WSC 00000
Address 02: Auto Trans Labels: None
Part No: 4D0 927 156 EM
Component: AG5 01L 4.2l5V USA 1011
Coding: 01102
Shop #: WSC 02313
End --------------------------------------------------------------------------------------------------
Thank for the help
Any ideas?
02
Coding: 06753
Shop #: WSC 02313
Coding: 08397
Shop #: WSC 02313
Coding: 00180
Shop #: WSC 02313
Coding: 00417
Shop #: WSC 02313
Coding: 01015
Shop #: WSC 02313
Coding: 02383
Shop #: WSC 91449
No Faults Found
No Faults Found
Coding: 16173
Shop #: WSC 23320
Coding: 00001
Shop #: WSC 00000
Coding: 00001
Shop #: WSC 00000
Coding: 00265
Shop #: WSC 02313
Coding: 22119
Shop #: WSC 02313
Coding: 0003333
Shop #: WSC 08213
Coding: 01108
Shop #: WSC 00000
Coding: 01102
Shop #: WSC 02313
Thank for the help
Hi guys
48 views and no replies.
I realize having a 12 hour clock is not a compelling issue but somebody must have an idea.
Regarding the coding, the only info I could find on the D2 S8 was by translating openbd.org with babelfish.
Clicking and right clicking on the actual coding for the instrument labels did not give me any info.
Any suggestions from the Vag Com guys ????
Until the coding is sorted out, ....
For clock times before Noon, just take the numerical value shown directly, IE 08:00 is 8:00 AM For times after noon, IE 15:00 just subtract 12 and add PM IE 15:00 -12 is 3:00 PM.
Reviewing the A8/6/4 instument lable files the country coding is fairly consistant, and afaik, is the only way to change the clock display format. Maybe you could email Sebastian at Ross Tech for advice?
Re: Until the coding is sorted out, ....
Thanks ...not to sound unappreciative but I do know how to read a 24 hour clock.
The thing that suprised me was the lack of instrument lable files for the A8 S8.
The files I found on opendb.org showed I was using the right country code but there was no mention of clock settings like there were for the A4 A6.
Maybe Audi believes all the Canadian A8 S8 owners want a 24 hour clock.
I will forward this to Sebastian for advice
Thanks
Thanks
Yeah, I figured that, but just in case.... :>)
I have the same issue with the clock only in my case Audi believes everyone in the US must want 12 hour clock displays. I'm used to, and prefer 24 hour format. It is annoying the clock display format is not independently configurable. I can set coding to UK, for miles and 24 hour format, but then other unintended/undesired consequences result.
So I'm not the only one
with this issue.
I just wanted to make sure I was'nt missing something obvious. However it was weird that it did display in 12 hour format for about a minute before reverting to the 24 hr clock.
I don't know why the clock display format changed back like that. .....
I can suggest a possible theory why, the IC uses the VIN to automatically configure some of the specific IC characteristics according to equipment and options fitted, maybe that is involved with the clock display reverting back to 24 hrs format. Did the coding value revert back also, or stay as entered? If VIN based self learning is involved, I don't know how to override that right now. Maybe entering a different pseudo VIN? I do know that Sebastian is the authority to consult regarding this problem, hopefully he can help. (His skills are in high demand, and finding time is likely an issue, so if you inquire, it may take awhile for him to get to it, but he is very good with follow ups.)
tjscanlon
05-14-2007 07:21 AM
