VAG-COM Discussion
Sponsored by:
Sponsored by:
18262-P1854 code. Not found in wiki update (recent post). Can anyone help?
Old 06-13-2007, 04:28 AM
broke90's Avatar
Old 06-13-2007, 05:08 AM
Audiworld Premium Sponsor
Andy@Ross-Tech's Avatar
What is the full text from VAG-COM (both lines)?
Andy
Old 06-13-2007, 01:58 PM
Theresias's Avatar
Actually a full Auto-Scan would be best in this specific case...
Old 06-15-2007, 05:14 AM
broke90's Avatar
Default Here's the full text...
VAG-COM Version: Release 409.1-US
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 02: Auto Trans
Controller: 8D0 927 156 BA
Component: AG5 01V 2.4l5V RdW 2526
Coding: 00003
Shop #: WSC 06325
1 Fault Found:
18262 - Powertrain Data Bus: Hardware Malfunction
P1854 - 35-10 - - - Intermittent
Old 06-15-2007, 05:32 AM
Any faults in any other modules? Could point to a wiring problem if no,
Andy
Old 06-15-2007, 12:31 PM
Theresias's Avatar
That's not a full Auto-Scan.
Old 06-15-2007, 10:28 PM
broke90's Avatar
Default I had some controller non-respond errors (don't know what that means) when auto-scan...
I'm running 409.1 shareware and bought the USB cable on eBay if any help. VAG-COM is all new experience for me and so wanting to learn.
TIA.
Old 06-15-2007, 10:29 PM
broke90's Avatar
The ABS and ASR warning lights take turns coming on if that's got anything to do with this.
Old 06-16-2007, 05:47 AM
theaudidoctor's Avatar
Default If there are ABS lights flashing - Start there
If the ABS light is flashing start there. It sounds like your ABS cont. unit on the pump is bad. Easy to confirm. When the light is on try and get into ABS (03). If you get in it will likely have an inst. cluster info. code (forget the number). If you can't get in, try the ECM (01)and/or inst. cluster (17). If you can't get into either of these, go to your ABS pump/cont. module (left side engine comp. in front of brake booster)and disconnect the electrical connector (slide the lock bar back paralel to the harness, pull connecter off). Now try and get into 01 or 17 again. If now you can get in, the ABS control unit on the pump is bad. It is available seperatly of the pump. They go out quite often.
If this is not the case, I would check the elect. connector @ the trans, clear the codes and see if it returns.
Old 06-16-2007, 05:49 AM
BTW - your engine is a 2.8, not a 2.4
Quick Reply: 18262-P1854 code. Not found in wiki update (recent post). Can anyone help?
