VAG-COM Discussion
Sponsored by:
Sponsored by:
2000 Audi a6 won't run with MAF sensor plugged in
Old 07-19-2014, 06:28 AM
Ruger280's Avatar
Default 2000 Audi a6 won't run with MAF sensor plugged in
I've tried several different things on this car, I replaced the MAF sensor,(no luck), cleaned the MAF sensor,(no luck), cleared the codes,(no luck). I'm stuck, HELP PLEASE. The A6 runs good with the MAF unplugged in, then dies after plugging it in.Is there a way of diagnosing this problem without taking it to a service center? The nearest one to me is 2 hours away. Thanks, Guys
Old 07-19-2014, 07:19 AM
jakematic's Avatar
Do you have one of these ?
If so please post a complete Auto-Scan.
Is it a genuine OEM MAF and not a cheap knock off ?
Any vacuum leaks ?
Old 07-19-2014, 02:33 PM
Ruger280's Avatar
Default Thanks for the quick reply--MAF sensor
Any vacuum leaks ?
It is a Remanned Cardone sensor, No I don't have one of those and where can I get one? (How Much?) I am new to owning an Audi, I got a really good buy on it and couldn't pass it up. As far as vacuum leaks, I don't know where to look. Thanks again, Craig
Old 07-19-2014, 03:11 PM
jakematic's Avatar
Hey Craig-
No worries, glad to assist.
You can get a VCDS cable from the link in my previous reply for $349.
Sometimes you find them on the classifieds here too, but don't expect to find a genuine version for much less than ~$300.
Don't waste you time with knock offs - they just end in frustration and lost cash.
These pay for themselves in no time; most Audi dealerships charge $125+/hr for diagnostics.
And as you can see they hold their value very well if you ever decide to sell it
Vacuum leak - all the hoses, MAF connections, etc.
VCDS will definitely help track the problem down.
Have a look at the interactive demo/manual here: http://www.ross-tech.com/vcds/tour/main_screen.html
The Ross-Tech team is a great bunch of enthusiasts with a rock solid product.
Below is a recent scan of my Audi so you can get an idea of how deep this tool communicates with the vehicle.
The diagnostic procedures for your 2000 can be found here.
Glad you got a got a good deal, and hopefully we can get it running perfectly soon.
Don't hesitate to look around the C5 forum and talk to the guys over there too - a wealth of information and experience.
-Jake
Code:
#hndoc:?docid=00000503&xt=hnh:3701E6637479F705686FE696C5C688B81C20096324C8D6CBAAB2EDF33F7E7F7E
VCDS Mobile 0.4111.0.4
VIN: WAURVAFD6CN014370
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 34 36 3B 3C 42
	 46 47 48 52 53 56 5B 5F 62 6C 6D 6F 72 81 85 88 89 8A 8B 8D
	 8E 8F 90
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
48-Seat, Rear, DS -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
88-Multicont. Seat Driver -- Status: OK 0000
89-Multicont. Seat Pass. -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
8F-Pretension. Front Left -- Status: OK 0000
90-Pretension. Front Right -- Status: OK 0000
Address 01: Engine  (CDRA
 -----)	Labels:4H-01.lbl
	Part No SW: 4H0 907 560 C	HW: 4H0 907 560
	Component: 4.2l V8/4V    H07 0004
	Revision: N5H07---
	Coding: 0106000A290F0268
	Shop #: WSC 02313 785 00200
	ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
	ROD: EV_ECM42FSI0114H0907560C.rod
	VCID: 2A1791ABD5B2A1427AB7DE-807F
No fault codes found.
Address 02: Auto Trans  (J217)	Labels:None
	Part No SW: 4H1 927 158 BR	HW: 0BK 927 156 K
	Component: 0BK 42 FSIUSA H08 1001
	Revision: --H08---
	Coding: 000002
	Shop #: WSC 00000 000 00000
	ASAM Dataset: EV_TCMALX51011 002018
	ROD: EV_TCMALX51011_AU64.rod
	VCID: 814596078844021A8B1D81-80D4
Address 03: ABS Brakes  (J104)	Labels:4H0-907-379.clb
	Part No SW: 4H0 907 379 C	HW: 4H0 907 379 C
	Component: ESP PREMIUM   H10 0273
	Revision: --------
	Coding: 44E6F20022674F00E200
	Shop #: WSC 02311 785 00200
	ASAM Dataset: EV_ESPPremi 005006
	ROD: EV_ESPPremi_AU64.rod
	VCID: 322789CBFD62E982C2E726-8067
Address 05: Acc/Start Auth.  (J393)	Labels:8K0-907-064-05.clb
	Part No SW: 4H0 907 064 DD	HW: 4H0 907 064 BD
	Component: BCM2 2.0      H31 0510
	Revision: 00002001
	Coding: 0D872000000000000000
	Shop #: WSC 39028 001 1048576
	VCID: 6E9F5DBB29DA9562E65FB2-803B
	Subsystem 1 -
	Subsystem 2 - 	Part No SW: 4H0-905-852-C
	Component: J764 ELV MLB H39 0046
Address 06: Seat Mem. Pass  (J521)	Labels:None
	Part No SW: 4H0 959 760 E	HW: 4H0 959 760 E
	Component: MEM-BFS       H08 0153
	Revision: AA000000
	Coding: C018B60085043201010001010101112131313333283333
	VCID: 352DB2D70C0CE6BAE70545-8060
Address 08: Auto HVAC  (J255)	Labels:None
	Part No SW: 4H0 820 043 H	HW: 4H0 820 043 H
	Component: Klima 4 Zonen H20 0072
	Coding: 480122BECC
	ASAM Dataset: EV_AirCondiFront 001050
	ROD: EV_AirCondiFront_AU64.rod
	VCID: 250D6297BCAC8E3A576595-8070
Address 0E: Media Player 1  (R161)	Labels:None
	Part No SW: 4H0 035 108 E	HW: 4H0 035 108
	Component: DVDCAlpine    H42 0190
	Revision: AA001001
	Coding: 010000
	VCID: 2207798BAD826102324776-8077
Address 10: Park/Steer Assist  (J446)	Labels:4H0-919-475-7X2.clb
	Part No SW: 4H0 919 475 L	HW: 4H0 919 475 C
	Component: PARKHILFE ACC H07 0043
	Revision: 11001001
	Coding: 280902
	ASAM Dataset: EV_EPHVA18AU57X0000 002005
	ROD: EV_EPHVA18AU57X0000.rod
	VCID: 3B39A4EF2A2828CA114183-806E
Address 13: Auto Dist. Reg  (J428)	Labels:None
	Part No SW: 4H0 907 561 A	HW: 4H0 907 561
	Component: ACC3          H15 0160
	Coding: 3601020201
	ASAM Dataset: EV_AdaptCruisContrAU64X 001012
	ROD: EV_AdaptCruisContrAU64X.rod
	VCID: 29156EA7D0B4AA5A738DC9-807C
Address 15: Airbags  (J234)	Labels:None
	Part No SW: 4H0 959 655 D	HW: 4H0 959 655 D
	Component: Airbag10.43   H41 0041
	Revision: --------
	Coding: 303143303230303030314A55304C34483053
	ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
	ROD: EV_AirbaAU10BPAAU64X_AU57.rod
	VCID: 3731B8DF16000CAAF5396F-8062
	Subsystem 1 - 	Part No SW: 4H0-959-339
	Component: BF-Gewichtss.H02 0040
	Serial Number: 5850000R1190801Y2Nªª
	Coding: 000000
	Subsystem 2 - 	Serial Number: 3575HRB405D0NI366PV.
	Subsystem 3 - 	Serial Number: 3585HRB40550Q3SK39JQ
	Subsystem 4 - 	Serial Number: 3515JRB404R0Q8K4FOSG
	Subsystem 5 - 	Serial Number: 3525JRB404R0Q8K46G6L
	Subsystem 6 - 	Serial Number: 3554VRB40610M5SO0H1M
	Subsystem 7 - 	Serial Number: 3564VRB40610M5SO493L
Address 16: Steering wheel  (J527)	Labels:None
	Part No SW: 4H0 953 568 G	HW: 4H0 953 568 G
	Component: Lenks.Modul   H03 0005
	Revision: --------
	Coding: 0000BC
	VCID: 3731B8DF160014AAF5396F-8062
	Subsystem 1 - 	Part No SW: 4H0-951-528-L
	Component: E221 - MFL   H04 0009
Address 17: Instruments  (J285)	Labels:4H0-920-xxx-17.clb
	Part No SW: 4H0 920 980 H	HW: 4H0 920 980 H
	Component: TBenUSAACC--- H38 0373
	Revision: 32480030
	Coding: 0B4F08015700D705020000
	ASAM Dataset: EV_RBD4K 004040
	ROD: EV_RBD4K.rod
	VCID: 302383C3F36EDB92B4F31C-8065
Address 19: CAN Gateway  (J533)	Labels:None
	Part No SW: 4H0 907 468 F	HW: 4H0 907 468 C
	Component: J533--Gateway H08 0213
	Revision: --------
	Coding: 00C1034A00
	ASAM Dataset: EV_GatewUDS 001025
	ROD: EV_GatewUDS_AU57.rod
	VCID: 342B8FD30776E7B2D01B30-8061
	Subsystem 1 - 	Part No SW: 4H0-915-181
	Component: J367-BDM     H07 0140
	Serial Number: 00000000005650628220
Address 28: HVAC, Rear  (E265)	Labels:None
	Part No SW: 4H0 919 158 D	HW: 4H0 919 158 D
	Component: Klima Fond    H15 0062
	Coding: 0000000000
	ASAM Dataset: EV_AirCondiHeck 001039
	ROD: EV_AirCondiHeck_AU64.rod
	VCID: 312586C7F864D29ABBFD11-8064
Address 34: Level Control  (J197)	Labels:None
	Part No SW: 4H0 907 553 C	HW: 4H0 907 553
	Component: LUFE-DAEMPFER H17 0096
	Coding: 008002
	ASAM Dataset: EV_AirSuspe 003022
	ROD: EV_AirSuspe_AU64.rod
	VCID: 2C1B97B3DF46BF7288ABE8-8079
Address 36: Seat Mem. Drvr  (J136)	Labels:None
	Component: MEM-FS        H08 0153
	Revision: AA000000
	Coding: C018BF8085853201030001010101112131313333203333
Address 3B: Sensor Elect.  (J849)	Labels:None
	Part No SW: 4H0 907 637	HW: 4H0 907 637
	Component: SARA 6D       H02 0015
	Revision: --------
	ASAM Dataset: EV_SARA 006014
	ROD: EV_SARA.rod
	VCID: EC9BD7B39FC6FF72482B28-80B9
Address 3C: Lane Change	Labels:None
	Part No SW: 4H0 907 566 A	HW: 4G0907568
	Component: J769  SWA MasterH01  0030
	Revision: 00H01000	Serial Number: 6PZ 010 287-07
	Coding: 0000002
	VCID: 2E1F9DBBE95A5562A6DFF2-807B
	Subsystem 1 - 	Part No SW: 4H0-907-568-A
	Component: J770  SWA Slave H02  0030
	Serial Number: 6PZ 010 287-27
Address 42: Door Elect, Driver  (J386)	Labels:None
	Part No SW: 4H0 959 793 M	HW: 4H0 959 793 E
	Component: TSG FA        H02 0166
	Revision: --------
	Coding: 011F1F205E0062C202000017
	Shop #: WSC 02312 785 00200
	VCID: 43C9DC0F52D8480A59B1EB-8016
Address 46: Central Conv.  (J393)	Labels:4H0-907-064-46.clb
	Revision: 00002001
	Coding: 0106023A00FA759FB0B0C780020100000000000000000000000000000000
	Subsystem 1 - 	Part No SW: 4H0-959-719
	Component: GTO BF       H01 0070
	Subsystem 2 - 	Part No SW: 1K0-951-605-C
	Component: LIN BACKUP HOH05 1501
	Subsystem 3 - 	Part No SW: 4H4-959-591
	Component: J245  007C   H06 0005
	Coding: 020200
	Subsystem 4 - 	Part No SW: 4H0-947-135-BRÿXd@
	Component: DachelektroniH11 0080
	Coding: 070000
	Subsystem 5 - 	Part No SW: 4H4-959-591
	Component: J394  0014   H06 0005
	Coding: 020200
	Subsystem 6 - 	Part No SW: 4H4-959-591
	Component: J392  006A   H06 0005
	Coding: 020200
	Subsystem 7 - 	Part No SW: 4H4-959-591
	Component: J867  00E0   H06 0005
	Coding: 020200
Address 47: Sound System	Labels:None
	Part No SW: 4G0 035 223 B	HW: 4G0 035 223 A
	Component: 0130H07
	Revision: CJ007000
	Coding: 030000
	VCID: 1C7B47738FE657F2F80B38-8049
Address 48: Seat, Rear, DS  (J876)	Labels:None
	Part No SW: 4H0 959 860	HW: 4H0 959 860
	Component: MEM-FS-Fond   H06 0153
	Revision: AA000000
	Coding: 001892800000300D0A00392038193A2039203B3B202020
	VCID: F1A5C6C7B8E40A9A7B7D51-80A4
Address 52: Door Elect, Pass.  (J387)	Labels:None
	Part No SW: 4H0 959 792 E	HW: 4H0 959 792 E
	Component: TSG BF        H02 0166
	Revision: --------
	Coding: 011F1F205E0062C202000007
	VCID: 3A37A1EB251209C20A578E-806F
Address 53: Parking Brake  (----)	Labels:4H0-907-801.clb
	Part No SW: 4H0 907 801 E	HW: 4H0 907 801 A
	Component: EPB-4         H03 0012
	Revision: --------
	ASAM Dataset: EV_ParkiBrake 001022
	ROD: EV_ParkiBrake_AU48.rod
Address 56: Radio  (R)	Labels:None
	Part No SW: 4H0 035 082 B	HW: 4H0 035 082
	Component: Radio U SIRIU H52 0076
	Revision: AB001007
	Coding: 020007010000000001
	VCID: 20037383A38E731224536C-8075
Address 5B: Seat,Rear,PS  (J877)	Labels:None
	Component: MEM-BFS-Fond  H06 0153
	Revision: AA000000
	Coding: 001896800000300D0A00392038193A2039203B3B382020
Address 5F: Information Electr.  (J794)	Labels:4E0-035-6xx-5F.clb
	Part No SW: 4H0 035 746 D	HW: 4H0 035 746
	Component: H-BNT-NA      H48 0423
	Revision: --------
	Coding: 020200000001F9EF7D128B0E00000003140001000000000000
	VCID: 29156EA7D0B4B25A738DC9-807C
	Subsystem 1 - 	Part No SW: 8R0-060-884-ADpre></pr
	Component: NAR 2011     0505
	Subsystem 2 - 	Part No SW: 4H0-919-604-D
	Component: DU8 D4 SV NB H47 0021
	Subsystem 3 - 	Part No SW: 4H1-919-600-F
	Component: E380 BDT D4  H09 0064
	Subsystem 4 - 	Part No SW: 8R0-060-961-B
	Component: CD-Database  3371
Address 62: Door, Rear Left  (J388)	Labels:None
	Part No SW: 4H0 959 795 A	HW: 4H0 959 795 A
	Component: TSG HL        H04 0167
	Revision: --------
	Coding: 010F1F20420062C202000007
	VCID: 3935BEE7201402DA032D79-806C
Address 6C: Back-up Cam.	Labels:4H0-907-441.clb
	Part No SW: 4H0 907 441 A	HW: 4H0907441
	Component: SG Rueckfahrkamera   0061
	Revision: --H04---	Serial Number: 525 PA8J17D1M2
	Coding: 1080003
	Shop #: WSC 02391 785 00200
	VCID: 260F659BC1AA1D225E6FAA-8073
Address 6D: Trunk Elect.  (----)	Labels:None
	Part No SW: 4H0 959 107 R	HW: 4H0 959 107 M
	Component: HDSG-Modul    H11 0039
	Revision: 10011001
	Coding: 0210044100
	ASAM Dataset: EV_DeckLidContrUnit 001025
	ROD: EV_DeckLidContrUnit.rod
	VCID: 3D3DAAF7343C26FA2F75AD-8068
Address 6F: Centr. Conv. II  (J773)	Labels:None
	Part No SW: 4H0 907 412	HW: 4H0 907 412
	Component: ALM           H05 0004
	Revision: --------
	Coding: 000000
	ASAM Dataset: EV_Ambie 001008
	ROD: EV_Ambie.rod
	VCID: E389BC8F7218B00AF9F1CB-80B6
Address 72: Door, Rear Right  (J389)	Labels:None
	Component: TSG HR        H04 0167
	Revision: --------
Address 81: Gear Shift  (J587)	Labels:None
	Part No SW: 4H1 927 731 A	HW: 4H1 927 731 A
	Component: GSM-LL        H07 0083
	Revision: 0L0D5012
	ASAM Dataset: EV_GSM2x3Mono 001017
	ROD: EV_GSM2x3Mono.rod
	VCID: 2B1994AFDA48B84A81A1D3-807E
Address 85: On Board Cam.  (J852)	Labels:None
	Part No SW: 4G0 907 217	HW: 4H0 907 217 A
	Component: DPC-SG        H24 0036
	Revision: --------
	Coding: E9060000
	ASAM Dataset: EV_OnBoardCamerDPC 001007
	ROD: EV_OnBoardCamerDPC.rod
	VCID: E58DA2977C2CCE3A17E5D5-80B0
Address 88: Multicont. Seat Driver  (J873)	Labels:None
	Part No SW: 4H0 907 182 H	HW: 4H0 907 182 H
	Component: IVB           H07 0042
	Coding: 764FF2
	ASAM Dataset: EV_IVBDriveSideFrnt 001003
	ROD: EV_IVBDriveSideFrnt.rod
	VCID: 2F2180BFEE50C46AADC907-807A
Address 89: Multicont. Seat Pass.  (J872)	Labels:None
	Coding: 364FF2
	ASAM Dataset: EV_IVBPasseSideFrnt 001003
Address 8A: Multicont. Seat Rear,DS  (J875)	Labels:None
	Part No SW: 4H0 907 182 G	HW: 4H0 907 182 G
	Component: IVB           H08 0042
	Coding: 200F00
	ASAM Dataset: EV_IVBDriveSideRear 001003
	VCID: 2E1F9DBBE95ACD62A6DFF2-807B
Address 8B: Adaptive Cruise 2  (J428)	Labels:None
	Part No SW: 4H0 907 541 A	HW: 4H0 907 541
	Coding: 3601020201
	ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
	ROD: EV_AdaptCruisContr2AU57X.rod
	VCID: 2711689FC6A09C2A6599BF-8072
Address 8D: Multicont. Seat Rear,PS  (J874)	Labels:None
	Coding: 200F00
	ASAM Dataset: EV_IVBPasseSideRear 001003
Address 8E: Image Processing  (J851)	Labels:4G0-907-107.clb
	Part No SW: 4G0 907 107 C	HW: 4H0 907 107
	Component: BV-SG         H29 0036
	Coding: 02A19A000111
	ASAM Dataset: EV_BC7 001001
	ROD: EV_BC7.rod
	VCID: 260F659BC1AA85225E6FAA-8073
Address 8F: Pretension. Front Left  (J854)	Labels:4H0-980-94x-RGS.clb
	Part No SW: 4H0 980 945 B	HW: 4H0 980 945 B
	Component: RGS-VL        H13 0080
	Coding: 0066F609031F037E070308014240C2010000
	ASAM Dataset: EV_RGS_L 002004
	ROD: EV_RGS_L.rod
Address 90: Pretension. Front Right  (J855)	Labels:4H0-980-94x-RGS.clb
	Part No SW: 4H0 980 946 B	HW: 4H0 980 946 B
	Component: RGS-VR        H13 0080
	ASAM Dataset: EV_RGS_R 002004
	ROD: EV_RGS_R.rod
Old 07-27-2014, 04:43 PM
Ruger280's Avatar
Problem with MAF sensor solved---Well kind of
Thanks for the help from jakematic, I found a hose off that goes into the turbo. I guess that was the problem. After hooking it up I plugged in the MAF and it idles fine now. Thanks, ALL you guys---You're great help!!
Old 07-27-2014, 04:50 PM
Ruger280's Avatar
Audi a6 2.7 chokes down at half throttle.
I'm stumped again,I changing the fuel filter My code scanner says I had a misfire #5 cylinder.After I got the MAF sensor problem resolved, I cleared the codes and none has come up since. I would REALLY love to be able to drive this car but I also have overheating issues too. Again I'm asking for your much appreciated help. Thank You Guys So Much
Old 07-28-2014, 05:54 AM
jakematic's Avatar
We'll need to see a complete Auto-Scan to see what's going on here.
See differences here: Ross-Tech: VCDS: DTC Comparison
Overheating could be any number of things.
Without a scan we're just throwing (expensive) parts at it blindly
j31izzle
03-08-2005 05:48 PM
Hokie - STI avant
12v V6 Discussion
11
12-30-2003 01:42 PM
Dave951
05-31-2003 08:44 AM
hondakiller
11-11-2002 07:56 PM
Quick Reply: 2000 Audi a6 won't run with MAF sensor plugged in
