VAG-COM Discussion
Sponsored by:
Sponsored by:
anyone use older serial vagcom with radio shack usb converter?
Old 08-05-2010, 09:23 PM
juttin's Avatar
Default anyone use older serial vagcom with radio shack usb converter?
I think I got the unicom vag device which was working fine with the radio shack adapter on my 99.5 audi but its not working with 05 a4 I just got. Some things work but not engine and instruments # 17 I believe. Get baud sync error. So I was just wondering if anyone was able to get it to work by changing speeds and other settings around. I tried changing some but no luck. I know there's that pcmcia serial adapter but that's just as expensive as a new vag tool from ross. Thanx justin
Old 08-06-2010, 03:20 PM
Theresias's Avatar
You may want to consider our upgrade program, money well spent - especially because VCDS-lite (or even the old VAG-COM 311/409) is not really up for all the stuff in a 2005 Audi A4.
USB<>RS232 Adapters will usually give you some trouble to begin with, depending on their quality and configuration it gets worse.
eseer
VAG-COM Discussion
05-22-2006 02:16 PM
MZimm
10-14-2005 08:29 PM
boxster02
05-29-2005 04:39 PM
formerly dennisA4
11-17-2002 03:52 PM
goody6691(gt3076 )
09-25-2002 11:01 AM
Quick Reply: anyone use older serial vagcom with radio shack usb converter?
