VAG-COM Discussion
Sponsored by:
Sponsored by:
2003 A4 3.0 Fault Codes & advice
Old 10-17-2012, 07:54 AM
harryzwd's Avatar
Default 2003 A4 3.0 Fault Codes & advice
Hey all - as a new VAG COM user, i thought i would reach out to this huge knowledge base and ask some advice as to what the following fault codes mean...are these common problems, signs or larger issues, etc? What should me path be to fixing or resolving the problems indicated. Thank you in advance for any advice
Tuesday,16,October,2012,18:16:46:38565
VCDS Version: Release 11.11.4 (x64)
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 E HW: 8E0 909 059
Component: 3.0L V6/5V G 0004
Coding: 0016751
1 Fault Found:
19759 - Exhaust Camshaft Position Sensor Bank 2 (G301)
P3303 - 001 - Open or Short to Plus - Intermittent
Readiness: 0010 1001
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04497
Shop #: WSC 06435
1 Fault Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 L
Component: A4 Klimaautomat 1116
Coding: 00000
2 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
41-10 - Blocked or No Voltage - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
Old 10-17-2012, 08:40 AM
Audiworld Premium Sponsor
bearthebruce's Avatar
All of the faults are intermittent. As such, it means the fault was triggered since the last time faults were cleared but the fault was not present at the time of the scan. So, unless you are having difficulties with the operation of these systems, I would suggest clearing the fault codes and then wait a few days to see if something comes back. If it does, then begin troubleshooting.
If you are having trouble with some portion of the car, then tell us about the problems and we'll make more recommendations.
-Bruce-
Ross-Tech, LLC
Old 10-17-2012, 09:33 AM
harryzwd's Avatar
i am getting a MIL or check engine light every so often. it will usually come on for a couple of days, then go off for a couple of days - that's what prompted me to perform the scan.
i will clear the codes and re-scan after i see a check engine light or in a couple of days, your software makes it easy enough to do.
thank you for your quick reply!
Old 10-17-2012, 10:29 AM
harryzwd's Avatar
i just did a rescan after seeing the MIL come back on:
Wednesday,17,October,2012,14:17:49:38565
Data version: 20120807
69 75 76 77
VIN: WAULT68Exxxx Mileage: 136340km/84717miles
Coding: 0016751
Shop #: WSC 78901 281 394790
VCID: 37772FA245DB21A0D0F
4 Faults Found:
P3303 - 001 - Open or Short to Plus - Intermittent - MIL ON
19756 - Exhaust Camshaft Position Sensor Bank 1 (G300)
P3300 - 002 - Short to Ground - Intermittent - MIL ON
18406 - Friction too High; Intake Cam Adjustement Bank 2
P1998 - 008 -
18404 - Friction too High; Intake Cam Adjustement Bank 1
P1996 - 008 -
Readiness: 0000 1000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8E0 927 156 Q
Component: AG5 01V 3.0l5V USA 0912
Coding: 0001002
Shop #: WSC 63351 000 00000
VCID: 3C7D308E7CFD02F83DD
No fault code found.
Coding: 04497
Shop #: WSC 06435
VCID: 2D5B0DCAE7879B70BA3
Coding: 00000
Shop #: WSC 63351
VCID: 2A5106D6D6698C485F1
3 Faults Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
30-10 - Open or Short to Plus - Intermittent
41-00 - Blocked or No Voltage
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00013
Shop #: WSC 63351
VCID: 346D18AE04ADCAB8F5D
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 2000
Coding: 0010607
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 02041
Shop #: WSC 63351
VCID: 3C7D308E2CFD02F83DD
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 03200
Shop #: WSC 08252
VCID: 32611EB6FEB9C488E71
WAULT68E13A196498 AUZ6Z0B0274049
1 Fault Found:
01304 - Radio
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0203
Coding: 00002
Shop #: WSC 63351
VCID: F1E351BABB3F3F905EB
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
VCID: EBDF43D29913D540647
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 11788
Shop #: WSC 06435
VCID: 72E1DEB63E398488271
Subsystem 1 - Part No: 8E1959801
Component: Tõrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0002
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0002
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D08
Coding: 00060
Shop #: WSC 63351
VCID: 040D886E148DBA3805D
End ---------------------------------------------------------------------
Old 10-17-2012, 12:21 PM
The MIL is because the Camshaft position sensor is wonky. You are going to need to determine if the sensor is bad or the wiring to it is the problem. The friction error are new this scan so you may have some mechanical going wonky in the engine. No choice but to start looking at that area of the engine.
You may find some help on our wiki:
http://wiki.ross-tech.com/wiki/index...6/P1998/006552
http://wiki.ross-tech.com/wiki/index...4/P1996/006550
Deal with the engine and then look at the HVAC stuff. That's convenience stuff.
-Bruce-
Ross-Tech, LLC
Old 10-17-2012, 12:28 PM
harryzwd's Avatar
that's great information, will do - thank you!
Old 10-17-2012, 01:04 PM
harryzwd's Avatar
i was able to measure blocks 90, 91 and 92 - a log file of which can be found here: (download from gray box below the green box)
http://www.filedropper.com/log-01-090-091-092
DZA
09-09-2009 05:57 AM
CvTech
12-25-2008 03:38 PM
rmarin2
VAG-COM Discussion
02-21-2008 03:35 AM
S4iowa
VAG-COM Discussion
02-08-2008 01:51 PM
SilverSchwinn
09-12-2006 04:08 AM
Quick Reply: 2003 A4 3.0 Fault Codes & advice
