2010 Q7 VAG-COM Mods - Window and Roof Control via Fob & Emergency Brake Flash
I've been working with my local shop to make some mods to my 2010 Q7 and so far we've only been able to enable the needle sweep. I am looking to enable Window and Sunroof open/close via the key fob and the emergency brake flash. I've found several posts here and on other forums that provide the following information:
Enable Remote Operation Windows and Sunroof
[46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
Bit 2 - Set to 1
Emergency Brake Flashing Lights
[46 - Comfort System]
[Coding - 07] -> [Long Coding Helper] -> Byte 8:
Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
Here's where I am stuck... My local shop is running the current version (14.10.0)of VCDS, and when we access 46-Central Conv., then Coding-07 we aren't seeing the "Long Coding Helper" per the instructions to enable either of these features. Do I have the wrong instructions?
I've attached step by step screen shots below that show what we are experiencing. Any help in getting these mods enabled would be greatly appreciated! Thanks!!
Main Menu Selected 46-Central Conv.
Selected Coding-07
Next screen after selecting Coding-07. (You'll notice no Long Coding Helper selection and the Comfort System (J393) Coding screen appears)
After clicking X on Comfort System (J393) Coding screen, the Recode Module screen is present and still no Long Coding Helper as previous instructions indicate.
Bit 2 - Set to 1
Selected Coding-07
+001 = Comfort Closing: Window Regulators via Remote Control
+002 = Comfort Opening: Window Regulators via Remote Control
+004 = Comfort Closing: Sunroof via Remote Control
+008 = Comfort Opening: Sunroof via Remote Control
I suspect that I would need to do similar for the Emergency Brake Flash, but under Channel 050: Adaptive Brake Light instead
+1 = Emergency Brake Blinking
Do you think I'm on the right path? Given that I'm a novice to this, I really don't want to risk messing up the computer in my Q7.
I appreciate the help!
Thanks!
The emergency braking coding may not work on NAR vehicles, but I'm not sure where you are.
Make sure to SAVE an Autoscan BEFORE you change anything.
That way if something goes wrong you can go back to the original coding.
