A4 b8 2009 DRL-Turn signal thread.
Hello.
My question is not about dimming or winking DRL, but i have a problem.
I disliked the bulb style turn signal on my b8, so.. this happened:
Managed to code drl-s off with turn signal (before that, they just turned dimmer while turn signal was on).
But had to adapt turn signal dimming brightness to 0 and now while in low beam or high beam mode, DRLs dont light up at all. When light switch was in low/high beam or in parked position or auto and off, it only dimmed to 9%, not turning off.
What i am searching for:
Light switch positions:
0 = DRL burning 100%, when turn signal is used, it turns off correct side drl.
auto
Parking lights = DRL burning at 9% OR 100%, when using turn signals need to make DRL turn off.
Headlights on (low beam, high beam) , DRL burn 9% or 100%, and when using turn signal, make DRL turn OFF, not to dim at 9%.
I just need to make DRL led strips turn off EVERY time whenever, whatever i use turn signals, does anyone know, is that possible ?
Thank you.
Silver
auto
Thank you.
Silver
Sorry for triple post. but other idea i had .. how does front turn signals and drl leds function in US markets, with headlights on, off, parking position etc.
Tryed to google and search youtube but did not find anything about the lights. maybe ,, again, sameone knows. or does anyone have original long coding from a4 b8 with drl led headlights ?
StraySheep
TT (Mk3) Discussion
26
01-04-2023 03:04 AM
CTA4AVANT
12-23-2008 07:13 AM
