A6 C5 4F Rear Turning Blinkers faults
Grateful for Your Help.
Does anyone know the VCDS code for the turning rear blinkers on as I think I turned them off when I was configuring the car keys to remotely shut the windows?
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01128829450000
Coding: 0000001
Shop #: WSC 02335 785 00200
VCID: 316F6586A85E30962BD-8064
2 Faults Found:
01505 - Bulb for Blinkers; Rear Right (M8)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 10
Reset counter: 91
Mileage: 200470 km
Time Indication: 0
Date: 2015.04.04
Time: 18:33:47
01501 - Bulb for Blinkers; Rear Left (M6)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 91
Mileage: 200470 km
Time Indication: 0
Date: 2015.04.04
Time: 18:33:50
Note I have check both rear turning bulbs and they are OK, I cannot find any fuses to test?
Otherwise any ideas what else to do, other than changing the control unit?
Coding: 0000001
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 91
Mileage: 200470 km
Time Indication: 0
Date: 2015.04.04
Time: 18:33:47
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 91
Mileage: 200470 km
Time Indication: 0
Date: 2015.04.04
Time: 18:33:50
Problem Solved, for all user of VCDS software always make note of the code before you change it. Other you can get into serious trouble, like I did, fortunately after search the WWW to solution and reading 1000 of messages, I found out that VCDS keep a coding log of what you have done, once you have found it put the old code back, otherwise its a trip to the Audi servicing agent and coming out £1500 lighter after they have changed you central controller and up loaded new software. A very salutary lesson has been learnt!
oldAGE
A6 (C7 Platform) Discussion
07-06-2017 11:55 AM
Avants
02-02-2006 12:11 PM
