adaptation woes.
adaptation woes.
Hi,
I lowered the suspension on my 2006 Audi A8 earlier today, it all went ok and i did the adaption ok. So tonight, I thought I would lower it a little bit more to 20mm front and 15mm rear.
But this time, the adaption wont take hold. On the third channel, it comes up with "ERROR Security Access" and I cant complete the adaption.
I've tried multiple times.
1, enter security code
2, adaption - channel 1, ok
3, Adaption - channel 2, ok
4, Adaption - Chanel 3, security error.
So I set the basic settings back to 55 and tried again. Same thing. So now my car is in limp mode, it wont go into 'lift' mode so I cant get it out of my driveway!
Any help appreciated.
Paul.
Paul.
I got the cable from a company called vag-com on amazon, the cable does say Ross tech on it though? Would you advise that I call Ross tech?
Regardless, I still have the issue with the cable..
Paul.
Audiworld Premium Sponsor
Good luck!
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
And sorry about the time that was posted.
Hopefully a mod will edit your title so it doesn't mislead those looking for authentic Ross Tech info...
You had your opportunity to buy their product prior to anyone not being nice, and you still went with a boot leg cable.
I'm sure if you had contacted Ross Tech prior to making a purchase they would have confirmed then that your seller was suspect.
How do I know that? Because I did EXACTLY that prior to buying mine online. Was told the seller was an authorized distributor with no issues.
Contact your seller and have them diagnose the problem? Or maybe you're using stolen Ross Tech software as well with the boot leg cable?...
All the info you needed from the top of this forum- https://www.audiworld.com/forums/sho....php?t=2794237
That's a bit off the deep end, no?
When I first looked, I did find Ross tech's website as well other websites. But to me, its just a diagnostic cable!
Ross tech should put something on their web page warning that they are the only makers of these leads/software. It would save a lot of confusion then?
