AngryAlex, here are the graphs from Block 115
AudiWorld Expert
Each line block is 600 RPMs, max is 2.5 Bar, etc...
Also, the first mbar number is requested boost, the second is actual boost. You will need to subtract ~1000 mbar (Block 113 read ~985-990 mbar) from both of these numbers to get the "real" boost numbers. Subtract 1000 mbar for atmospheric pressure.
<img src="http://pictureposter.audiworld.com/1308/vag1.jpg">
<img src="http://pictureposter.audiworld.com/1308/vag2.jpg">
<img src="http://pictureposter.audiworld.com/1308/vag3.jpg">
<img src="http://pictureposter.audiworld.com/1308/vag4.jpg">
<img src="http://pictureposter.audiworld.com/1308/vag6.jpg">
<img src="http://pictureposter.audiworld.com/1308/vag7.jpg">
AudiWorld Expert
No prob...
I wish I remembered what gear you were in for each boost graph.
There are at least two things to consider from the graphs:
1) As long as the requested boost and the actual boost are close (less than 100mBar?), then you are doing ok.
2) Confirm the boost obtained at the given RPM (red graph line).
Graph Posting Tip:
JPGs don't work well for these kinds of images. If the tools you're using support it, save your screen-shots as PNGs and they'll be much clearer.
Oh, and I almost forgot: VAG-Scope 1.4 is fully resizeable, and the thickness of the plot-lines can be tweaked too..<ul><li><a href="http://www.ross-tech.com/vag-scope/downloads.html">VAG-Scope Download Page</a></li></ul>
http://www.Ross-Tech.com
ECS Tuning-Audi
RS4 (B7 Platform) Discussion
08-14-2017 08:39 AM
ECS Tuning-Audi
09-28-2015 12:18 PM
ECS Tuning-Audi
09-28-2015 11:46 AM
ECS Tuning-Audi
TT (Mk2) Discussion
09-28-2015 11:41 AM
