VAG-COM Discussion
Sponsored by:
Sponsored by:
Another Security Access question
Old 05-28-2006, 03:16 PM
DirkM's Avatar
Default Another Security Access question
Ok, a plain VAG-COM 512.4 with HEX-USB+CAN question.
Checking channel 16 on a RNS-E 8E0 035 193 E with US sw 0110, I get a "Security Access required" message. Entering a Security Access code results in a "Security access accepted" message but I still get the "Security Access required" message when trying to access channel 16.
How do I have to enter the Security Access code or is a VAS required to read this channel?
Thanks,
Dirk
Old 05-29-2006, 05:54 AM
Audiworld Premium Sponsor
Uwe@Ross-Tech.com's Avatar
Default Sounds like the security access code you have
is not the correct one needed to grant access to that channel. A control module can have more than one valid security access code.
A VAS-505x won't get you any further without the appropriate security access code.
-Uwe-
http://www.Ross-Tech.com
Old 05-29-2006, 08:20 AM
DirkM's Avatar
Default Thanks, Uwe,
I could swear that the number I have was the only number between 00000 and 99999 that was accepted by VAG-COM as Security Access code but there is a chance that I skipped a couple. Looks like I have to try it again.
Old 05-30-2006, 07:21 AM
Default Huh? You tried 10000 different numbers?
How long did that take? :-)
Brute force attacks on the Security Access function are generally not effective. Most modules will lock out this function (meaning they will reject even a valid code) for some time after a low number of attempts with incorrect codes.
-Uwe-
Old 05-30-2006, 07:33 AM
DirkM's Avatar
Default I tried 100.000 numbers and it took about 3 weeks.
Well, I didn't them by hand obviously but scripted VAG-COM to perform the tasks. The RNS-E returns a "Security Access code not valid" if the code is wrong and if you try again it says something about invalid seed. But leaving the module and going back in works. I would love to not have to do this but so far everybody who knows what I'm after doesn't tell me how to achieve this.
BTW, did you know that VAG-COM stops working after entering a Security Access code 719 times? To proceed you have to exit and relaunch VAG-COM.
Old 05-31-2006, 06:56 AM
Default Nope didn't know that.
What software are you using to script it?
-Uwe-
Old 05-31-2006, 07:07 AM
DirkM's Avatar
Winbatch
Chalfont
10-16-2007 05:19 PM
A3 dreamer
Audi A3 / S3 / RS 3
04-15-2006 04:15 PM
TCRAIG
08-18-2005 09:10 AM
XCCESS
11
03-18-2005 08:55 AM
mj2.7
04-11-2002 10:01 AM
Quick Reply: Another Security Access question
