Audi A8 3.2 4E abs coding
Hi
I need help coding my ABS ,,, please help me,,
here is Auto scan:
___________________________________________
Tuesday,27,November,2012,12:09:23:62881
VCDS Version: Release 11.11.4
Data version: 20120807
FERWANA GROUP
Chassis Type: 4E0
Scan: 01 02 03 05 07 08 09 15 16 17 19 1E 25 34 37 38 42 46 47 4F
52 53 55 56 61 62 67 72 76 77
VIN: WAUKH44E56N013852 Mileage: 83800km/52070miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 1010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine (AUK) Labels: 06C-909-559-ASN.lbl
Part No SW: 4E1 910 559 A HW: 8E0 907 559
Component: 3.2l V6 FSI 0010
Revision: --H16--- Serial number: AUX3Z0E9575948
Coding: 0106000002070120
Shop #: WSC 02313 785 00200
VCID: 285F3D499B06BA58495
4 Faults Found:
005634 - Power Supply Terminal 30
P1602 - 008 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 27.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
005648 - Internal Control Module
P1610 - 006 - Memory Check Sum Error - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 54.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
005715 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 22
Reset counter: 40
Mileage: 83802 km
Time Indication: 0
Date: 2012.11.17
Time: 22:24:18
Freeze Frame:
RPM: 1440 /min
Mass Air / Rev.: 119.9 mg/str
Temperature: 43.5°C
Idle
Load: 17.3 %
Speed: 0.0 km/h
012372 - Starter Will Not Turn
P3054 - 006 - Jammed or Electrical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Date: 2012.11.19
Time: 18:15:46
Freeze Frame:
RPM: 0 /min
Temperature: 27.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Readiness: 0010 0000
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 4E0 910 155 N HW: 01J 927 156 JG
Component: V30 01J 3.2l 4V RdW 0010
Revision: --H04--- Serial number: 00000000001114
Coding: 0000001
Shop #: WSC 04926 001 00001
VCID: 2C57C1598FFE9678ADD
1 Fault Found:
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 8
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 09:27:55
Freeze Frame:
RPM: 768 /min
RPM: 0 /min
(no units): 13.0
Torque: -10.0 Nm
Temperature: 40.0°C
T.B. Angle: 0.0°
Bin. Bits: 0101 0 0
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 A
Component: ESP 5.7 allrad H29 0420
Coding: 0000000
Shop #: WSC 00000 000 00000
VCID: 2149206DF83C4B100EB
5 Faults Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
00003 - Control Module
014 - Defective
01044 - Control Module Incorrectly Coded
000 - -
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
012 - Electrical Fault in Circuit
00285 - ABS Wheel Speed Sensor; Front Right (G45)
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 H
Component: FBS AUDID3 H07 0160
Revision: 01604707 Serial number: AUX3Z0E9575948
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: D8BFCD896BE64AD8B95
Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 0
Reset counter: 248
Mileage: 83760 km
Time Indication: 0
Date: 2012.10.15
Time: 01:21:14
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 P HW: 4E0 035 729
Component: Interfacebox H43 2120
Revision: 00000000 Serial number: 343JT057571165
Coding: 0000002
VCID: 2D51CC5DB4E49F70BA3
Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
6 Faults Found:
02244 - Button in Control Head is Stuck
000 - - - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 39
Mileage: 83772 km
Time Indication: 0
Date: 2012.09.29
Time: 17:27:47
Freeze Frame:
Bin. Bits: 10000000
Bin. Bits: 0000000
Bin. Bits: 100
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 0
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 00:00:35
Freeze Frame:
Bin. Bits: 01
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 83802 km
Time Indication: 0
Date: 2012.11.17
Time: 18:50:14
01310 - Level Control System Control Module (J197)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 83802 km
Time Indication: 0
Date: 2012.11.17
Time: 18:50:14
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 83802 km
Time Indication: 0
Date: 2012.11.17
Time: 18:50:14
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 83802 km
Time Indication: 0
Date: 2012.11.17
Time: 18:50:14
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 C
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000078505
Coding: 0033729
Shop #: WSC 99900 715 03832
VCID: 1C371199DF5E66F8DDD
No fault code found.
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H13 0210
Coding: 0123111
Shop #: WSC 99900 715 87925
VCID: 3169D02DA8DCFB909EB
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000034
Shop #: WSC 99900
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 99900
2 Faults Found:
00908 - Control Module for Wiper Motor
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 2
Mileage: 1048575 km
Time Indication: 0
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 2
Mileage: 1048575 km
Time Indication: 0
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H12 3610
Revision: 91H12360 Serial number: 0037P00086LR
Coding: 0431707
VCID: 275D3E759618B52040F
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksنulenmodul H13 0040
Coding: 0012141
VCID: E5C1F47D2C94E730323
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 T HW: 4E0 920 900 T
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3E9004623
Coding: 0000613
Shop #: WSC 00715 999 91469
VCID: 306FD529A3D6F298915
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 2000305A268072
Coding: FCFE7BC42B7104
3 Faults Found:
01301 - Control Module for Voice Recognition (J507)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 134
Reset counter: 217
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 00:01:04
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 00:06:13
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 1
Mileage: 83777 km
Time Indication: 0
Date: 2012.10.21
Time: 00:11:27
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE8003069
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 248
Mileage: 83760 km
Time Indication: 0
Date: 2012.10.15
Time: 01:21:14
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 00999 715 87925
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 09:24:47
01400 - Suspension Level Control
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 00:29:22
01398 - Signal Conductor for Central Locking; Doors Open
Freeze Frame:
Fault Priority: 4
Fault Frequency: 12
Reset counter: 1
Mileage: 83784 km
Time Indication: 0
Date: 2012.10.29
Time: 17:59:50
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 D
Component: MNS ECE H46 0850
Revision: 00000000 Serial number: 364JQ057501508
VCID: 3B75F2057A9001C0347
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.04.03
Time: 23:03:35
Freeze Frame:
Bin. Bits: 1100
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000528300076
Coding: 0003222
VCID: 1D311C9DC4446FF02A3
1 Fault Found:
00410 - Pre-Selection Signal for Opening Sunroof
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 0
Fault Frequency: 15
Reset counter: 232
Mileage: 83772 km
Time Indication: 0
Date: 2012.09.16
Time: 17:47:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 A HW: 4E1 959 801 C
Component: Türsteuer.FSmBRM001 0110
Coding: 0002348
VCID: 1F4D2695CE487DE038F
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040511020287
Coding: 0004680
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 247
Mileage: 83771 km
Time Indication: 0
Date: 2012.03.28
Time: 17:12:23
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 J HW: 4E0 035 223 D
Component: Amp.-Basis H41 0120
Revision: 00000000 Serial number: 00000057505777
Coding: 0000016
VCID: 24472979E72E5E3865D
2 Faults Found:
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 00:11:32
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 00:28:36
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000072269
Coding: 0010101
VCID: 1E331B91C94274E8339
4 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 09:42:00
Freeze Frame:
Fault Priority: 3
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.04.03
Time: 23:04:00
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 00:28:00
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 09:42:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 A HW: 4E1 959 802 C
Component: Türsteuer.BFmBRM001 0110
Coding: 0002348
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0001211
Shop #: WSC 06386 210 01865
5 Faults Found:
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Freeze Frame:
Voltage: 10.77 V
Count: 247
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 151
Reset counter: 217
Mileage: 83768 km
Time Indication: 0
Date: 2012.10.15
Time: 00:00:15
Freeze Frame:
Voltage: 10.46 V
Count: 231
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 2
Reset counter: 0
Mileage: 83768 km
Time Indication: 0
Date: 2012.10.15
Time: 09:35:53
Freeze Frame:
Voltage: 10.87 V
Count: 41
01315 - Transmission Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 217
Mileage: 83800 km
Time Indication: 0
Date: 2012.11.26
Time: 23:12:37
Freeze Frame:
Voltage: 10.77 V
Count: 224
Freeze Frame:
Fault Priority: 3
Reset counter: 247
Mileage: 83768 km
Time Indication: 0
Date: 2012.03.28
Time: 17:12:18
Freeze Frame:
Voltage: 8.90 V
Count: 242
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000006
Shop #: WSC 99900 715 21563
VCID: 3D71FC1D64840FF00A3
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 83768 km
Time Indication: 0
Date: 2012.04.03
Time: 23:04:34
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 190
Mileage: 83768 km
Time Indication: 0
Date: 2012.08.09
Time: 14:50:09
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 83768 km
Time Indication: 0
Date: 2012.04.03
Time: 23:04:34
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 L HW: 4E0 035 541 L
Component: TUNER EU/US/RDW H42 0560
Revision: 00000000 Serial number: 304JS057610695
Coding: 0000001
VCID: 2959384D800C835056B
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000004784
VCID: 204F2569F3364218015
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 1510160384
Coding: 344530393135313035412056413031353130313630333834
Shop #: WSC 00000 128 00289
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 54
Mileage: 83772 km
Time Indication: 0
Date: 2012.09.15
Time: 10:02:46
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 31
Mileage: 83772 km
Time Indication: 0
Date: 2012.09.22
Time: 16:29:19
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 30
Mileage: 83772 km
Time Indication: 0
Date: 2012.09.22
Time: 16:29:29
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 29
Mileage: 83772 km
Time Indication: 0
Date: 2012.09.22
Time: 16:29:39
02256 - Quiescent Current
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 249
Mileage: 83776 km
Time Indication: 0
Date: 2012.10.17
Time: 02:54:45
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0002348
Address 67: Voice Control
Cannot be reached
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0002348
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720528501802
Coding: 0201108
VCID: 23452A65E22059001C7
4 Faults Found:
01626 - Sensor for Parking-Aid; Front Right (G252)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 249
Mileage: 83772 km
Time Indication: 0
Date: 2012.09.29
Time: 17:32:43
01543 - Parking Aid Warning Chime (H15)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 165
Mileage: 83772 km
Time Indication: 0
Date: 2012.04.03
Time: 23:04:16
Freeze Frame:
Fault Priority: 4
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.04.03
Time: 23:04:16
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 209
Mileage: 83772 km
Time Indication: 0
Date: 2012.07.18
Time: 13:01:31
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 F HW: 4E0 862 335
Component: Handyvorb2 H13 0580
Revision: 00000000 Serial number: 00000007588312
Coding: 0010900
VCID: 2541347DEC14A730723
End ----------------------------------------------------------
Ferwana Monzer
here is Auto scan:
FERWANA GROUP
Chassis Type: 4E0
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 27.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Temperature: 54.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
P1653 - 008 -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 22
Reset counter: 40
Mileage: 83802 km
Time Indication: 0
Date: 2012.11.17
Time: 22:24:18
Freeze Frame:
RPM: 1440 /min
Temperature: 43.5°C
Idle
Load: 17.3 %
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Date: 2012.11.19
Time: 18:15:46
Freeze Frame:
RPM: 0 /min
Temperature: 27.0°C
Engine Off
Load: 0.0 %
Speed: 0.0 km/h
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 8
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 09:27:55
Freeze Frame:
RPM: 768 /min
RPM: 0 /min
(no units): 13.0
Torque: -10.0 Nm
Temperature: 40.0°C
T.B. Angle: 0.0°
Bin. Bits: 0101 0 0
Coding: 0000000
5 Faults Found:
014 - Defective
000 - -
Coding: 0263168
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 248
Mileage: 83760 km
Time Indication: 0
Date: 2012.10.15
Time: 01:21:14
Coding: 0000002
6 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 39
Mileage: 83772 km
Time Indication: 0
Date: 2012.09.29
Time: 17:27:47
Freeze Frame:
Bin. Bits: 10000000
Bin. Bits: 0000000
Bin. Bits: 100
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 0
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 00:00:35
Freeze Frame:
Bin. Bits: 01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 83802 km
Time Indication: 0
Date: 2012.11.17
Time: 18:50:14
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 83802 km
Time Indication: 0
Date: 2012.11.17
Time: 18:50:14
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 83802 km
Time Indication: 0
Date: 2012.11.17
Time: 18:50:14
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Mileage: 83802 km
Time Indication: 0
Date: 2012.11.17
Time: 18:50:14
Coding: 0033729
Coding: 0123111
Coding: 00000034
Shop #: WSC 99900
Coding: 00139548
Shop #: WSC 99900
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 2
Mileage: 1048575 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 2
Mileage: 1048575 km
Time Indication: 0
Coding: 0431707
Coding: 0012141
Coding: 0000613
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 217
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 00:01:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 00:06:13
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 1
Mileage: 83777 km
Time Indication: 0
Date: 2012.10.21
Time: 00:11:27
Coding: 0263168
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 248
Mileage: 83760 km
Time Indication: 0
Date: 2012.10.15
Time: 01:21:14
Coding: 0015510
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 09:24:47
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 00:29:22
Freeze Frame:
Fault Priority: 4
Fault Frequency: 12
Reset counter: 1
Mileage: 83784 km
Time Indication: 0
Date: 2012.10.29
Time: 17:59:50
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.04.03
Time: 23:03:35
Freeze Frame:
Bin. Bits: 1100
Coding: 0003222
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 15
Reset counter: 232
Mileage: 83772 km
Time Indication: 0
Date: 2012.09.16
Time: 17:47:00
Coding: 0002348
Coding: 0004680
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 247
Mileage: 83771 km
Time Indication: 0
Date: 2012.03.28
Time: 17:12:23
Coding: 0000016
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 00:11:32
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 00:28:36
Coding: 0010101
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 09:42:00
Freeze Frame:
Fault Priority: 3
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.04.03
Time: 23:04:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 00:28:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.10.15
Time: 09:42:00
Coding: 0002348
Revision: A32C0220
Coding: 0001211
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Freeze Frame:
Voltage: 10.77 V
Count: 247
Freeze Frame:
Fault Priority: 3
Reset counter: 217
Mileage: 83768 km
Time Indication: 0
Date: 2012.10.15
Time: 00:00:15
Freeze Frame:
Voltage: 10.46 V
Count: 231
00576 - Terminal 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 0
Mileage: 83768 km
Time Indication: 0
Date: 2012.10.15
Time: 09:35:53
Freeze Frame:
Voltage: 10.87 V
Count: 41
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 217
Mileage: 83800 km
Time Indication: 0
Date: 2012.11.26
Time: 23:12:37
Freeze Frame:
Voltage: 10.77 V
Count: 224
Freeze Frame:
Fault Priority: 3
Reset counter: 247
Mileage: 83768 km
Time Indication: 0
Date: 2012.03.28
Time: 17:12:18
Freeze Frame:
Voltage: 8.90 V
Count: 242
Coding: 0000006
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 83768 km
Time Indication: 0
Date: 2012.04.03
Time: 23:04:34
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 190
Mileage: 83768 km
Time Indication: 0
Date: 2012.08.09
Time: 14:50:09
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 83768 km
Time Indication: 0
Date: 2012.04.03
Time: 23:04:34
Coding: 0000001
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 54
Mileage: 83772 km
Time Indication: 0
Date: 2012.09.15
Time: 10:02:46
Freeze Frame:
Fault Priority: 7
Fault Frequency: 31
Mileage: 83772 km
Time Indication: 0
Date: 2012.09.22
Time: 16:29:19
Freeze Frame:
Fault Priority: 7
Fault Frequency: 30
Mileage: 83772 km
Time Indication: 0
Date: 2012.09.22
Time: 16:29:29
Freeze Frame:
Fault Priority: 7
Fault Frequency: 29
Mileage: 83772 km
Time Indication: 0
Date: 2012.09.22
Time: 16:29:39
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 249
Mileage: 83776 km
Time Indication: 0
Date: 2012.10.17
Time: 02:54:45
Coding: 0002348
Cannot be reached
Coding: 0002348
Coding: 0201108
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 249
Mileage: 83772 km
Time Indication: 0
Date: 2012.09.29
Time: 17:32:43
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 165
Mileage: 83772 km
Time Indication: 0
Date: 2012.04.03
Time: 23:04:16
Freeze Frame:
Fault Priority: 4
Reset counter: 247
Mileage: 83772 km
Time Indication: 0
Date: 2012.04.03
Time: 23:04:16
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 209
Mileage: 83772 km
Time Indication: 0
Date: 2012.07.18
Time: 13:01:31
Coding: 0010900
Ferwana Monzer
Danielfive5
06-12-2019 11:04 AM
