B6 1.8TQS - Help with Codes
I have been throwing these codes about once a month for the last few months. I clear them and they will get thrown again after a few weeks. The car has 124K miles on it, and the vacume hoses look good. Any ideas?
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8E0 909 518 F
Component and/or Version: 1.8L R4/5VT G 0001
Software Coding: 0016701
Work Shop Code: WSC 63351
2 Faults Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 002 - Lower Limit Exceeded - Intermittent
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 002 - Lower Limit Exceeded
2 Faults Found:
Been here?
<ul><li><a href="http://wiki.ross-tech.com/index.php/Category:Fault_Codes">http://wiki.ross-tech.com/index.php/Category:Fault_Codes</a</li></ul>
http://www.Ross-Tech.com
SOLVED!!!!
FYI.....well I did not check the vacume hoses well enough. I took a closer look about 2 weeks ago and the vac hose to the combi valve was completely disconnected. Reconnected and zip tied it.....so far so good.
Steviecef
03-17-2004 08:46 AM
