VAG-COM Discussion
Sponsored by:
Sponsored by:
B7 A4 ECU Help Needed, J757 Relay Output
Old 07-16-2016, 10:27 AM
WESRACE's Avatar
Default B7 A4 ECU Help Needed, J757 Relay Output
I have a 2006 Audi A4 Quattro 2.0T B7 chassis with an APR K04 S3 turbo and need to reach out to the community for tech support before I go about replacing a costly ECU and then having to ship it to APR to re-program it to my car.
After several days of troubleshooting, the diagnosis seems to point to an intermittently faulty ECU as everything else has been tested or replaced with the exception of the APR HP Fuel Pump solenoid (N276). I have pulled a VAG-COM log an attached it to the email and included additional information below. I have done output tests on the ECU and the J757 relay which supplies the circuit power to the N276 valve and N75 valve is not consistently responding (both relays and the N75 were replaced, see below).
The car starts rough with 4-5 cranks and throws the P codes immediately most times, if the codes are cleared it will drive fine and you can hear the solenoid responding on the fuel pump during idle. Typically, at startup it will throw the codes again, with it often going into limp mode and when in limp mode you don't hear the HP FP solenoid. When the car starts on first crank then there are typically no p-codes.
I believe this to be internal to the ECU as I recently tapped on the ECU plastic housing cover and the J757 relay began responding again to an output test, but that was a single occurrence that I have not been able to reproduce Please advise.
Summary of P Codes:
Primary Codes (most common, usually at engine start):
P0245- Solenoid Valve for Boost Pressure Control (N75): Short to Ground*
P2295-Fuel Pressure Regulator Valve (N276): Short to Ground*
Other common codes (associated with primary codes):
P2294-Fuel Pressure Regulator Valve (N276): Open Circuit
2293- Fuel Pressure Regulator Valve (N276): Mechanical Malfunction
P0243-Solenoid Valve for Boost Pressure Control (N75): Malfunction
Secondary Codes (typically follows the others):
P0135-Oxygen (Lambda) Sensor B1 S1; Heating Circuit: Malfunction
P0130-Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0037-Oxygen (Lambda) Sensor B1 S2: Heating Circuit: Short to Ground
P0036-Oxygen (Lambda) Sensor B1 S2: Heating Circuit: Open Circuit
Ongoing efforts to resolve:
July-14 (5 HR): Replaced both 70 amp ECU power relays, the J757-Engine Component Current Supply Relay and the J271-Mototronic Current Supply Relay (these are typically replaced in pairs). Note, the J757 relay supplies power to the N75 wastegate solenoid and the N276 HP fuel pump solenoid. Replaced the 0.5mm dia red/blue wire that supplied ground to the J757 relay coil ground from to the ECU 94 pin main harness at terminal 32 (T94/32) due to poor continuity, see Audi Current flow diagram No. 78/3. Note, all fuses were checked and none were blown.
July-12 (1 HR): Replaced the turbocharger waste gate solenoid (N75) with a new Audi part (codes returned).
Recent Maintenance Activity (likely unrelated):
June-6: New thermostat manifold (06D-121-111-G)
May-16: New PCV valve and gasket installed: 06F-129-101-R
April-02: New serpentine belt and tensioner (06D-903-137-E and 06B-903-133-E)
April-02: Oil change 5w40 synthetic
Mar-22: 4 new Audi Coil Packs (06E-905-115-E) and 4 new OEM Spark plugs (06H-905-601-A)
Dec-29: New HPFP cam follower (worn) and replaced drivetrain lubricants
Old 07-16-2016, 05:55 PM
WESRACE's Avatar
First time posting...how about some help?
Old 07-22-2016, 05:54 AM
WESRACE's Avatar
ECU ordered.. will post the results.
Old 10-09-2016, 02:08 PM
Joe77's Avatar
Sorry I can't help but it sounds like your knowledgeable. My son has an Audi B6 or B7 A4 Quattro, not sure which. The windshield wipers stopped working for whatever reason which led us on a turkey hunt that led us to the ECU also. I unplugged the ECU, with the battery still attached. To make a long story short I plugged the ECU back in and now it will not start. A code reader can't read thru OBDII now, it says error1. I think we damaged the ECU just by unplugging it. Do you know if we order or acquire a used ECU if we have to program it to this specific vehicle? Who is APR, where you mentioned you might send yours? Have you heard of this Roos-Tech cable to reprogram ECU's?
Thanks
Old 05-17-2020, 01:25 PM
FlyinGoat's Avatar
Did you ever figure this out?? I seem to have the exact same symptoms on my A4.
Old 05-17-2020, 02:21 PM
FlyinGoat's Avatar
Well in case anyone else has this issue be sure to check all your fuses. I replaced a 15amp fuse in my ECU bay that was burnt out and it fixed all my codes. Car was running terribly. Misfiring and going into limp mode.
Audi A4 2.0T 2006
Old 07-27-2020, 06:37 PM
N3RY70-25's Avatar
Summary of P Codes:
Where did you get the ECM ...?
Jairek
13
06-03-2010 04:32 AM
OjNK
10
01-10-2008 10:24 AM
Duke TT
12-06-2006 10:20 PM
mikemoor
11-06-2005 12:40 AM
boxerfan
9
04-22-2005 03:02 PM
Quick Reply: B7 A4 ECU Help Needed, J757 Relay Output
