VAG-COM Discussion
Sponsored by:
Sponsored by:
B8 3 faults
Old 01-04-2014, 11:32 AM
awss4's Avatar
Default B8 3 faults
My 2009 A4 2.0T just lite up the check engine light.
A VAG scan indicated the following 3 faults, all are priority 2.
It is hard to believe that they are unrelated. The scan is less then 2 hours after the check engine came on. Anybody have any thoughts? Thanks
Mileage: 60710km-37723mi
Address 01: Engine Labels: 06H-907-115-CAB.clb
Control Module Part Number: 8K2 907 115 AL HW: 8K2 907 115 D
Component and/or Version: 2.0l R4/4V TF H12 0001
Software Coding: 0104010A190F0160
Work Shop Code: WSC 22302 444 64321
ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001 (AU48)
VCID: 79F20805F8696AD6D3D-802C
3 Faults Found:
8113 - Performance Malfunction in Cooling System
P2181 00 [237] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 60654 km
Date: 2014.01.02
Time: 15:29:12
4629 - ECM Power Relay Load Circuit: (J271)
P068A 00 [032] - De-Energized Performance Too Early
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 60654 km
Date: 2014.01.02
Time: 15:29:12
5671 - Boost Pressure Regulation
P0299 00 [096] - Control Range Not Reached
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 60654 km
Date: 2014.01.02
Time: 15:29:12
Readiness: 0000 0000
iestatic
S4 (B8 Platform) Discussion
20
07-15-2022 09:43 PM
bballfreak
9
04-14-2019 06:59 PM
Kerry G
05-18-2018 06:12 AM
saifxnyc
09-24-2015 10:26 PM
Quick Reply: B8 3 faults
