VAG-COM Discussion
Sponsored by:
Sponsored by:
New to this Q7 07 3.6
Old 08-17-2014, 07:07 AM
walsaadi's Avatar
Default New to this Q7 07 3.6
Hi all so after my extended warranty ended I decided to by the vag-com mobile to check my car by myself I'll attached the full scan and I appreciate if can give my any advices and how to read it
Also is there any codes that I can add or modify to get more features or better performance ? I heard that I can close and close all windows and slide roof from my key !!
Thanks for your help
auto scan audi Q7 07
#hndoc:?docid=00000542&xt=hnh:9313874D4693B2CD0A59 A6D3855D95B9B9C3D17A069CBCB5119CCCE4A52F7AAB
VCDS Mobile 0.4112.0.4
VIN: WA1BY74L77D031368
Chassis Type:4L or FE
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 13 15 16 17 18 19 1E 28
34 36 37 3C 42 46 47 4F 52 55 56 57 5C 61 62 65 67 69 6C 6D
6F 72 76 77
Address 01: Engine Labels: 03H-906-032-BLV.lbl
Part No SW: 03H 906 032 L HW: 03H906032G
Component: Q7 3.6-FSI-LEV2 G00 9970
Revision: --H03--- Serial Number:
Coding: 0001175
Shop #: WSC 31414 790 00001
VCID: 2B1994AFD83F201CD8A1CC-807E
No fault codes found.
Address 02: Auto Trans Labels: None
Part No SW: 4L0 910 156 A HW: 0AT927156
Component: AG6 0AT 3,6 FSI USA 0040
Revision: --H01--- Serial Number: 4001811
Coding: 0000002
VCID: 2711689FC4D7047C3C99A0-8072
Address 03: ABS Brakes Labels: 4L0-910-517.clb
Part No SW: 4L0 910 517 A HW: 4L0614517A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H21001
Coding: 0017425
VCID: 28136BA3C9C90B043583AB-807D
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4L0907335
Component: FBSAUDIC6 ELV H31 0210
Revision: 27120501 Serial Number: 10601000480992
Coding: 0000135
VCID: E389BC8F706F285CA0F1D4-80B6
Subsystem 1 - Part No SW: 4F0-910-131-L
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No SW: 4F0-910-335
Component: FBSAUDIC6 KSG H27 0080
7 Faults Found:
00191 - Passenger's Door Handle Touch Sensor (G416)
011 - Open Circuit
007 - Short to Ground
02764 - Access/Start Authorization Switch (E408)
008 - Implausible Signal - Intermittent
00193 - Right Rear Door Handle Touch Sensor (G418)
007 - Short to Ground - Intermittent
00955 - Key 1
002 - Lower Limit Exceeded - Intermittent
011 - Open Circuit - Intermittent
00956 - Key 2
Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
Part No SW: 4L0 910 732 R HW: 4L0919610B
Component: Interfacebox H43 4610
Revision: 00000000 Serial Number: 354GM067506025
Coding: 0002003
Shop #: WSC 93059 999 83948
VCID: 3833BBE319699B84A5237B-806D
Subsystem 1 - Part No SW: 4L0-910-609
Component: E0380 BedienteilH01 0060
Serial Number: 00000001014827
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0820043F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---008 Serial Number: 00000000049021
Coding: 0524326
VCID: E185B6876A733A4CB2DDBE-80B4
1 Fault Found:
00712 - Right Footwell Flap Positioning Motor (V109)
003 - Mechanical Failure - Intermittent
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4E0955559B
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial Number: 4F0907279
Coding: 0014123
Shop #: WSC 93272 999 70067
VCID: 312586C7FA134ACCE2FD0E-8064
Subsystem 1 - Part No SW: 4L1-910-113 Labels: 1Kx-955-119.clb
Component: Wischer AU716 H12 0080
Coding: 0064792
Subsystem 2 - Part No SW: 4E0-910-557-A Labels: 8K0-955-559.clb
Component: REGENLICHTSENSORH12 0090
Coding: 0150059
2 Faults Found:
01520 - Rain and Light Recognition Sensor (G397)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
01024 - Rain Sensor (G213)
014 - Defective - Intermittent
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 111 A HW: 4L0035111
Component: CD-Changer H41 0100
Revision: 00000000 Serial Number: AUZ5ZBF3028627
Shop #: WSC 00000 000 00000
VCID: 1E7F4D7B9B8DC5B44F3F5D-804B
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0035593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial Number: AUZ4Z7F3030677
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0959339
Component: 73 AIRBAG AUDI8RH39 0210
Revision: 03H39000 Serial Number: 0038QD032LH7
Coding: 0014131
Subsystem 1 - Part No SW: 4L0-910-339
Component: BF-Gewichtsens. H02 0020
Serial Number: 6332QSME0E0E3639O
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0953549A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial Number: 90055061750342
Coding: 0002042
VCID: E68FA59B835D5D7447EFF5-80B3
Subsystem 1 - Part No SW: XXX-XXX-XXX-XX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0920980H
Component: KOMBIINSTR. M73 H17 0240
Revision: 00300000 Serial Number: 5HH32L376
Coding: 2641363
Shop #: WSC 63481 000 1048576
VCID: 23097C8FB0EFE85C607194-8076
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0907468A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial Number: 0800D066078313
Coding: F5D7FE77347A02
Shop #: WSC 08959 444 58924
VCID: EC9BD7B39DB16724112B37-80B9
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4L0959760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial Number: 00000000896401
Coding: 0082954
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0919887D
Component: MNS US H48 1100
Revision: 00000000 Serial Number: 313FJ067502293
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 A HW: 4L0907568A
Component: J0769_SWA_MasterH06 0060
Revision: 00H06000 Serial Number: 6PZ 009 014-00
Coding: 0000001
VCID: 2C1B97B3DD312724D1ABF7-8079
Subsystem 1 - Part No SW: 4L0-910-568-A
Component: J0770_SWA_Slave_H05 0060
Serial Number: 6PZ 009 014-20
1 Fault Found:
02856 - Sensing Area for Control Module 2 Blocked
000 - - - Intermittent
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0959793B
Component: TSG FA H12 0130
Revision: 00000000 Serial Number: q1w
Coding: 0051915
VCID: 2F2180BFEC275C3CF4C918-807A
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0907289A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial Number: 01015735200000
Coding: 7632925
Subsystem 1 - Part No SW: 1K0-951-605-C
Component: LIN BACKUP HORN H03 1301
2 Faults Found:
01565 - Luggage Compartment Light (W3)
009 - Open or Short to Ground
03073 - Rear Lid Closed Sensor 1
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0035223D
Component: DSP-High AU716 H02 0150
Revision: PROD_01 Serial Number: 00000000005256
Coding: 0000026
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0907280B
Component: ILM Beifahrer H10 0080
Revision: Serial Number: 00000000030040
Coding: 0012001
VCID: DEFF8D7B5B0D05B48FBF9D-808B
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0959792B
Component: TSG BF H12 0130
Revision: 00-00000
Coding: 0051915
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0907357F
Component: AFS 1 H01 0020
Revision: 00000001 Serial Number:
Coding: 0000021
VCID: 29156EA7D2C3320C2A8DD6-807C
Subsystem 1 - Part No SW: 7L6-941-329-A
Component: AFS-Modul links H06 0002
Subsystem 2 - Part No SW: 7L6-941-329-A
Component: AFS-Modul rechtsH06 0002
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0035541P
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial Number: 388FY067537333
Coding: 0000002
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 HW: 4L0915181
Component: J0644 BEM H12 0530
Revision: -------- Serial Number: 00000000027673
Coding: 0000000
VCID: E48BBF9375612F6459FBDF-80B1
Subsystem 1 - Part No SW: 4F0-915-105-D
Component: von VA0 2607030057
2 Faults Found:
03041 - Energy Management Active
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0959795B
Component: TSG HL H21 0050
Coding: 0051722
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0907273A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial Number: 00000900025055
Coding: 0062424
VCID: 2207798BAFF5E1546B4769-8077
1 Fault Found:
02214 - Tire Pressure Warning
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0035753A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial Number: 00000605230111
Shop #: WSC 12336 024 394758
VCID: 342B8FD305017FE4891B2F-8061
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 HW: 4L0907441
Component: J772__Rearview 0020
Revision: --H10--- Serial Number: 525PA8-J660936
Coding: 1000101
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0827852A
Component: ValeoHeckdeckel H20 0280
Revision: --H20001 Serial Number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 1 - Part No SW: 4L0-910-946
Serial Number: E5030100B
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0959591
Component: ILM HINTEN 2 H05 0040
Revision: AAH05044 Serial Number: 001747340-----
Coding: 0003595
VCID: 260F659BC3DD1D74076FB5-8073
Subsystem 1 - Part No SW: 4L0-910-591
Component: J_245_EE14_SKB09H10 0160
Subsystem 2 - Part No SW: 4L0-910-591
Component: J_394_EE14_SKB09H10 0160
Subsystem 3 - Part No SW: 4L0-910-591
Component: J_392_EE14_SKB09H10 0160
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0959794B
Component: TSG HR H21 0050
Coding: 0051722
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0919283F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial Number: 06220616501478
Coding: 0021246
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0862335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial Number: 00000005081943
Coding: 0010900
Shop #: WSC 93059 999 98970
Old 08-17-2014, 09:49 AM
jakematic's Avatar
On the faults:
Code:
Coding: 0000135
7 Faults Found:
011 - Open Circuit
00955 - Key 1
00956 - Key 2
Something is wrong with the passenger side door handles.
I'd be more concerned with the 02764, but it is intermittent.
Code:
Coding: 0524326
1 Fault Found:
Will need replacing eventually
Code:
Coding: 0014123
Coding: 0064792
Coding: 0150059
2 Faults Found:
I would code this properly per the wiki or hints in VCDS itself
Code:
1 Fault Found:
000 - -
You can ignore this
Code:
Coding: 0000001
1 Fault Found:
Check / clean the area.
If it persists you'll need the dealer to align the sensors.
Code:
Coding: 7632925
2 Faults Found:
Check the wiring
Code:
Revision: 00-00000
Coding: 0051915
1 Fault Found:
Sensor in the previous fault most likely
Code:
Coding: 0000000
2 Faults Found:
This is normal - it's the vehicle going to sleep to preserve the battery
I'd clear all those DTCs and see what comes back after a few drive cycles.
There are modifications that can be done for window opening, etc.
Usually they are detailed in the model specific forum and sometimes on the Wiki.
Don't forget to register for VCDS Cloud access to enable coding in the Mobile version.
All of the functions are available if HEX-NET is wifi or USB connected to a laptop.
Old 08-17-2014, 10:51 AM
walsaadi's Avatar
Thanks jakematic
I'll clear all these faults and check again next weekend , I cannot lock the car from the passenger door exterior button !
What is wiki I read something like that on ross-tech website ?
Old 08-17-2014, 04:20 PM
jakematic's Avatar
Diagnostic Procedures: Diagnostic Procedures - Ross-Tech Wiki
Fault Codes: Category:Fault Codes - Ross-Tech Wiki
Old 08-17-2014, 05:10 PM
jakematic's Avatar
Default Window coding
Coding is here: Audi Q7 (4L) Comfort System - Ross-Tech Wiki
It will be a similar process to the D3 and C6 of the same era.
Have a look at this thread: https://www.audiworld.com/forums/a8-...g-com-2827318/ for more information.
Tonytza
VAG-COM Discussion
04-14-2008 07:14 AM
4.2LV8AUDI
VAG-COM Discussion
08-06-2007 01:38 PM
AudiRX
VAG-COM Discussion
01-25-2007 01:37 PM
AudiRX
VAG-COM Discussion
05-22-2006 12:05 AM
Quick Reply: New to this Q7 07 3.6
