A/C Issues...Need help with a VAG code
Thanks to Tyler in Derry, NH for the use of his VAG!
As I have posted before in the B5 forum, my A/C turns off after about 20 mins. and won't come back on until the car is completely cool (this is not a temp sensor issue, it has already been replaced).
Here is the VAG readout:
VAG-COM Version: Release 409.1-S
Control Module Part Number: 8D0 820 043 H
Component and/or Version: A4-KLIMAVOLLAUTOMAT_D65
Software Coding: 00062
Work Shop Code: WSC 06322
1 Fault Found:
01270 - A/C Magnetic Clutch (N25)
36-10 - Open Circuit - Intermittent
...Anyone have a clue of what this means???
Thanks!
Phil
1 Fault Found:
Thanks!
Phil
Re: Sounds like you need a new AC clutch...
Yes, I am betting that it is the clutch. Now the compressor is repeatedly engaging and disengaging.
How much $$ for a clutch?
Phil
Phil
Could be that your refrigerant leaked out?...
I don't have an Audi AC system schematic in front of me. But maybe there is a pressure sensor that is reporting that there is no refrigerant in the system.
Just a thought. This is exactly how my Jeep Grand Cherokee would tell me to please kindly add a pound of R134a. I know you are thinking, "What does a Jeep have to do with an Audi?!!"
The AC clutch is enabled by a relay when you ask for cold air. A sensor determines there's not enough pressure in the AC system, so ze KlimateKontroler kills the relay to the clutch periodically to save the compressor. Then ze KlimateKontroler system re-enables the clutch every few minutes to check if you dumped some refridgerant in there. Finding none, it disables the clutch and waits some more.
lscheres
17
10-15-2011 08:52 AM
Phil Manro
07-30-2005 11:53 AM
zapco98
06-24-2002 06:42 AM
