VAG-COM Discussion
Sponsored by:
Sponsored by:
A/C Magnetic Clutch Problem
Old 04-21-2006, 11:22 AM
New Member
adeyl's Avatar
Default A/C Magnetic Clutch Problem
Car is giving intermittent starting problem. Sometimes no start for 3 days and then it starts again- so no problem with the battery. I could listen to the the fuel pump relay energizing. Also, the A/C don't work and I could listen to the A/C Magnetic clutch's sound when right after the vehicle starts.
Did a VAG and found:
00799 - Coolant Temperature Sensor (G110)~ 30 - 00 - Open or Short to B+
01270 - A/C Magnetic Clutch (N25)~ 42-10 - Speed Deviation too High - Intermittent
Questions?
Can coolant temp sensor be a cause of intermittent starting problem?
Is there any place where I could buy just the magnetic clutch?
Can it be just the A/C Magnetic clutch relay showing up in VAG?
Could A/C Magnetic clutch relay be associated with the fact that there is compressor is empty?
Also where can I find the Transmission Code?
Already changed the starter switch but still intermittent no start? Ordered a temp sensor and will install next week.
Thanks in Advance
Audi A6 Quattro Sedan, 1996
Engine Code: AFC
Old 04-21-2006, 12:22 PM
Audiworld Premium Sponsor
Uwe@Ross-Tech.com's Avatar
Default Define "no start":
- cranks, but doesn't fire up?
- or won't crank at at all?
-Uwe-
http://www.Ross-Tech.com
Old 04-21-2006, 12:36 PM
New Member
adeyl's Avatar
Default Re: Define "no start":
Intermittent No Crank. Seems like there is no trouble code registered either.
Old 04-21-2006, 02:34 PM
Default Since cranking can't be blocked
by anything diagnstic capable on that car, you're gonna have to chase that the old-fashioned way, with a multimeter.
-Uwe-
Old 04-22-2006, 01:11 AM
New Member
adeyl's Avatar
Default What parts should to check with Multimeter?
Thanks for the clarification, Uwe.
What are the parts I need to check? I couldn't find a Starting diagram in ELSA.
Old 04-22-2006, 03:40 AM
xtreetoes's Avatar
Default Re: What parts should to check with Multimeter?
I would look at ignition switch and work from there...
Old 04-22-2006, 11:00 AM
New Member
adeyl's Avatar
Default Replaced Ignition Switch 2 months ago
Reading the forum, I though ignition switch as well. But if I try to start, I could hear the relay just no crank. Could it be faulty Ignition Relay? Will the relay register in VAG?
Car is working fine now, still worried which awkward moment it will stop.
Old 04-24-2006, 04:29 AM
Bracketracer's Avatar
Default probe the starter signal terminal on the starter, and have someone try to crank it...
while watching the test light.
Avantugofast
11
10-25-2008 11:42 AM
Lupis52
03-27-2005 08:48 PM
QuatroA8
02-22-2005 04:52 PM
Audiboi 2.7T
10-29-2004 04:13 AM
nospek3
06-29-2002 10:45 PM
Quick Reply: A/C Magnetic Clutch Problem
