VAG-COM Discussion
Sponsored by:
Sponsored by:
Can Gateway Coding Help!
Old 08-01-2009, 08:46 AM
hash666's Avatar
Default Can Gateway Coding Help!
Hello, i have just fitted an RCD310 into my mk5 golf to replace the RCD300. i replaced the can bus with a new revision S but now need to code it. i have no idea what the coding should be. i have vag com and the means to do it i just need help with the coding...
01-Engine -- Status: Not registered 0001
03-ABS Brakes -- Status: Not registered 0001
04-Steering Angle -- Status: Not registered 0001
08-Auto HVAC -- Status: Not registered 0011
09-Cent. Elect. -- Status: Not registered 0011
15-Airbags -- Status: Not registered 0001
16-Steering wheel -- Status: Not registered 0011
17-Instruments -- Status: Not registered 0001
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Not registered 0001
42-Door Elect, Driver -- Status: Not registered 0001
44-Steering Assist -- Status: Not registered 0001
46-Central Conv. -- Status: Not registered 0011
52-Door Elect, Pass. -- Status: Not registered 0001
56-Radio -- Status: Not registered 0011
7D-Aux. Heat -- Status: Not registered 0011
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 290609F1000784
Coding: 00000000000002000000
Shop #: WSC 00000 000 00000
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 15
Mileage: 81077 km
Time Indication: 0
Date: 2000.00.00
Time: 12:51:22
PLEASE HELP! THANKYOU
Old 08-01-2009, 06:14 PM
Audiworld Premium Sponsor
Uwe@Ross-Tech.com's Avatar
[Select]
[19-CAN Gateway]
[Installation List]
That gets you a screen like this:
Check the box corresponding to each of the modules in the list you posted above. Then click
[Save Coding]
-Uwe-
http://www.Ross-Tech.com
brandonb93
A4 (B7 Platform) Discussion
12
12-04-2018 01:16 PM
mxp
09-26-2015 10:15 AM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
09-25-2015 08:57 AM
ECS Tuning-Audi
09-25-2015 08:20 AM
mdkv5
A6 (C7 Platform) Discussion
09-16-2015 01:09 AM
Quick Reply: Can Gateway Coding Help!
