Can I Change Automatic to Shift With Thumb Paddles While in D? Using
#12
I don't know that a different TCU flash would effect this. I was speculating only. ...
A chip tuner could possibly impliment the Tip in D feature as provided on the 3l TCU. I don't know whats up with the coding you used on your friends '02. 000X0Y2, where X=1 "Tip paddles present on SW, X=0 "Tip paddles not present", Y=0 DSP active, Y=1 DSP not active. Values for Y other that 0 or 1 are not defined.
Make sure the Steering column Control Module is coded for tip Steering wheel function or equivalent, also.
BTW, when the TCU coding has 5 digits, that is early firmware version, later flash versions have 7 digits. IE, 0001002 vs 01002.
minman26
S4 (B8 Platform) Discussion
09-18-2015 03:08 PM
BlackA6
09-21-2003 12:42 PM
Young Audi Jedi
10-23-2002 05:32 PM
Roy
09-05-1999 12:27 PM
