Can I use this information for 2000 A6???
Can i use this information to check my airbag fault code?????<ul><li><a href="http://www.ross-tech.com/vag-com/download/label-files/4B0-959-655-AI8.lbl">Information from Ross-Tech</a></li></ul>
Depends.
What your airbag module's part number?
What label file does VAG-COM pull up?
What fault code do you have in your airbag system?
Edit: I see you posted that info a tread or two down. Why a separate thread for this question?
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Based upon your part number from the other thread (why do make 2 of them?)...
...you can use that file. Also future versions will use it automatically. You can simply put the linked file in the /VAG-COM/Labels/ folder and replace the existing one.<ul><li><a href="http://www.ross-tech.com/vag-com/download/label-files/4B-15.lbl">http://www.ross-tech.com/vag-com/download/label-files/4B-15.lbl</a</li></ul>
JimR
VAG-COM Discussion
01-24-2005 05:57 AM
gofastblue
10
06-05-2004 07:24 AM
