VAG-COM Discussion
Sponsored by:
Sponsored by:
Carista or other Choices?
Old 03-26-2016, 08:38 AM
mdskiman521's Avatar
Default Carista or other Choices?
Started to post this in the A6 C7 forum but maybe it belongs here.
Anyone using the Carista app for the A6? Having my Audi for almost a year now I started to look at customizing the MMI and the Carista appears to be a simple way to get started.
So I ordered the Bluetooth Carista Bluetooth ODB from Amazon yesterday and got it delivered last night with same day shipping.
I enabled the pro version. I see a lot of nice, easy to do customizations (see below). But I don't see a way to reset a service reminder. Resetting the service reminder seems like a basic function so I'm disappointed. Am I missing something?
I may still get a Ross Tech or one of the Autel Vag 505 products.
Also, I did try to set my windows to roll up/down with the key fob but it doesn't work yet.
Needle Sweep works.
Set the instrument cluster region to USA and now my display says S6
Anyone have a lot of success with Carista?
Here is what Carista says it can customize:
The following settings were available specifically toyour vehicle using Carista:
Doors / Windows / Remote
Auto-lock doors when moving
*YES* / NO
Auto-unlock doors when key is taken out of ignition
*YES* / NO
Auto-lock trunk when moving
*YES* / NO
Blink turn signals and beep when unlocking doors YES /*NO*
Beep when alarm is armed
*YES* / NO
Unlock doors via remote
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON1ST PRESS
Unlock doors via smart key (door handle button) *DRIVER'SDOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
Enable settings for opening/closing windows and sunroof
*YES* / NO
Open/close windows/sunroof/roof via long-press on remoteYES / *NO*
Close windows via long-press on remote
*YES* / NO
Open windows via long-press on remote
*YES* / NO
Close sunroof via long-press on remote
*YES* / NO
Open sunroof via long-press on remote
*YES* / NO
Sunroof action when opening via remote
SLIDE / *TILT*
Open/close only driver's window via remote or key YES /*NO*
Open/close windows and sunroof via smart key YES / *NO*
Close windows via smart key
*YES* / NO
Close sunroof via smart key
*YES* / NO
Open/close windows and sunroof by holding key in doorlock
*YES* / NO
Open windows by holding key in door lock
*YES* / NO
Open sunroof by holding key in door lock
*YES* / NO
Close windows by holding key in door lock
*YES* / NO
Close sunroof by holding key in door lock
*YES* / NO
Open/close convertible roof via long-press on remote YES/ *NO*
Close convertible roof via long-press on remote
*YES* / NO
Open convertible roof via long-press on remote
*YES* / NO
Close convertible roof by holding key in door lock
*YES* / NO
Open convertible roof by holding key in door lock
*YES* / NO
Close convertible roof via smart key
*YES* / NO
Blink turn signals when done closing windows via remoteYES / *NO*
Enable remote control when vehicle is running and in gear
*YES* / NO
Instruments / Display / Dings
Hidden menu in dash screen via holding CAR + SETUP (req.restart) ENABLED / *DISABLED*
Instrument cluster region (affects ext. lights too)
*GERMANY* / REST OF WORLD/LEFT-HAND DRIVE / USA / CANADA/ GREAT BRITAIN / JAPAN/LEFT-HAND DRIVE / ARABIAN STATES / AUSTRALIA / REST OFWORLD/RIGHT-HAND DRIVE / JAPAN/RIGHT-HAND DRIVE
Display warning about using navigation when moving
*YES* / NO
Gauge needle sweep at startup
YES / *NO*
Gauge needles lit even when headlights are off
*YES* / NO
Gauge scales lit even when headlights are off
*YES* / NO
Seat belt warning
DISABLED / *US/CANADA STYLE* / EURO STYLE 1 / EURO STYLE2 / EURO STYLE 3
Ding when headlights are left on
*YES* / NO
Lap timer
Navigation disc eject button
*ENABLED* / DISABLED
Lights
Allow configuring daytime running lights via dash display
*YES* / NO
Use front LED lights as daytime running lights YES / *NO*
Use fog lights as daytime running lights YES / *NO*
Use high beams as daytime running lights YES / *NO*
Use tail lights as daytime running lights YES / *NO*
Use side marker lights as daytime running lights YES /*NO*
Use low beams as daytime running lights
YES / *NO*
Turn off daytime running lights when parking lights areon YES / *NO*
Turn off daytime running lights ("wink") whenturn signal is on
*YES* / NO
Coming-home lights
Leaving-home lights
Use fog lights as coming-home lights
YES / *NO*
Use low beams as coming-home lights
*YES* / NO
Turn off front fog lights when high beams are on
*YES* / NO
Turn off rear fog lights when high beams are on
*YES* / NO
Cornering lights (using fog lights)
YES / *NO*
Allow configuring footwell lights
*YES* / NO
Front footwell lights while driving
Rear footwell lights while driving
Flash brake lights in emergency stopping YES / *NO*
Flash hazard lights in emergency stopping YES / *NO*
Turn on side marker lights with headlights (US modelsonly)
*YES* / NO
"Euro" parking lights when ignition off, turnsignal on YES / *NO*
Other
Lower passenger-side mirror when in reverse gear (req.memory seats)
*YES* / NO
Remember position when lowering passenger-side mirror inreverse gear
*YES* / NO
Old 09-03-2016, 07:10 PM
Dskvid's Avatar
How did the Carista work out?
Old 09-03-2016, 07:21 PM
snagitseven's Avatar
Once the comfort windows is changed in software it adds menu options in the MMI; you have to go into the MMI Car settings menu and enable the feature before it will work.
Old 09-25-2016, 05:21 PM
loudell's Avatar
Can you explain that again??
Old 09-25-2016, 06:11 PM
Just what I wrote. Changing a mod in Carista or Vag-Com to add the feature just creates a new menu item in the car's MMI. You then have to enable the key fob remote window/sunroof open/ close options in that menu for it to work.
Old 11-26-2016, 02:40 PM
Former Vendor
Carista's Avatar
Guys, quick update here: Carista now does have the service reminder reset feature. Just go into SERVICE -> "Service indicator reset".
About the windows-via-remote thing: as snagitseven said, when you enable opening windows via the remote in Carista, that creates a new menu in your MMI under Car -> Central locking (or similar) where you need to activate the feature for it to work. More info: http://www.caristaapp.com/2015/06/27...a4s4-b8-or-q5/
This is also a good time to mention our Black Friday / Cyber Monday deal on the hardware adapter: https://goo.gl/Y0CklK
Old 01-13-2017, 07:39 PM
waninae39's Avatar
the gear display does not work in a 2016 q5
all i get is comms failed
other functions do work
carista says that feature is experimental thus like some others , not guaranteed to work
mdskiman521
A6 (C7 Platform) Discussion
15
04-28-2016 12:39 PM
maartenv21
15
03-07-2015 01:37 PM
conwin
06-24-2011 09:12 AM
bikard
Audi 100 / A6 (C4 Platform)
06-05-2006 03:42 AM
Quick Reply: Carista or other Choices?
