Catalyst System Fault
Need help with this one. I have tried to use vagcom to find out if it's the before the cat oxegin sensor or after the cat. Any body have a clue? Thanks.
Tony
Address 01: Engine
Control Module Part Number: 8E0 909 518 F
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 0016751
Work Shop Code: WSC 63351
1 Fault Found:
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 002 - Lower Limit Exceeded - MIL ON
Readiness: 0000 0000
Tony
Address 01: Engine
1 Fault Found:
Send me an email with a complete scan from the car. I have a readiness script that will allow you to test the O2 Sensors and the Cat.
Santos@Ross-Tech.com
If you are not registered, please fill out this form:
http://www.ross-tech.com/vca/hex-com-reg.php
4Driver4
12-20-2007 05:36 PM
Trey (at pitt)
21
10-03-2007 11:54 AM
Nate (ETKA+Scumbag)
09-18-2005 04:08 PM
