Cellular antenna fault?
Just received my VAG-COM as birthday gift (I have a fantastic wife!) and my first scan is below. Only one fault - in module 5F - having to do with an open circuit in my cellular antenna. Here is just that portion of the scan:
1 Fault Found:
3073 - Cellular Antenna
B1053 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 146
Reset counter: 160
Mileage: 326 km
Date: 2016.06.17
Time: 08:21:57
Voltage terminal 30: 14.2 V
Any ideas on what this would indicate? My car seems to be pulling in cellular data OK as far as I can tell, and even the wifi hotspot is working.
Here is complete (first ever) scan of my 2016 Audi A3 Cabriolet:
Friday,26,August,2016,13:06:21:61930
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
Ross-Tech: Home
VIN: WAU38LFF2G1094306 License Plate:
Mileage: 5558km-3453mi Repair Order:
Chassis Type: FF (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 26 2B 3C 42 44 47 52 55
5F 6C
VIN: WAU38LFF2G1094306 Mileage: 5558km-3453miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
26-Auto Roof -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine (J623-CNTC) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 D HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0004
Revision: --H13---
Coding: 0A1D00124426000F3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0205G0906259D 001005
ROD: EV_ECM20TFS0205G0906259D.rod
VCID: 2F6C924376ECA63A09-807A
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 013 B HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4902
Revision: 06253104 Serial number: TFK01602231402
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 162247A7E97677F26A-8042
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 60766000001771
Coding: 11FF6A9234290A70017A030081C92988562C5080C08194B602 4100548208
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 79F86C1BF828B88AE7-802C
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0398406706
Coding: 030C0C
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_VW37.rod
VCID: 3A7AB317BDAE7392AE-806E
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H14 0060
Revision: 20028000 Serial number: 00000000891332
Coding: 05000004010000000000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 33649E339AC482DA6D-8066
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0005
Serial number: 8B290A1800PAG0MUFU01
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 085 BK HW: 5Q0 937 085 AE
Component: BCM MQBAB MNA H24 0175
Serial number: 01061607100441
Coding: 04051C46C04106FD4160400451100700090000000000000000 0000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_VW37.rod
VCID: 03040EF38AE4F25ABD-8056
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 160307 043 0585
Serial number: 160311044640
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 61504332
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Component: E1 - LDS MQB H05 0032
Serial number: 26 12 2015 00000660
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000065303002
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391606806837
Coding: 0030150011
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 4384CEF3CA64325AFD-8016
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AC HW: 5Q0 959 655 AC
Component: AirbagVW20 010 0830
Serial number: 003MNR007APV
Coding: 9DC0F0C00000A0005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002144
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 010804FB90F8E04AAF-8054
Belt Pretensioner left:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H36 0350
Serial number: 34229759A14031650954
Coding: 333135
Belt Pretensioner right:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H36 0350
Serial number: 34229760A14031641027
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 694000000000001G8GR1
Coding: 303333
Side Sensor Driver Front:
Subsystem 4 - Part No SW: ----------- HW: 480 001 603 16
Component: SideSensor_Df 001 0887
Serial number: 35700000000F5B111A1H
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 5 - Part No SW: ----------- HW: 480 001 603 16
Component: SideSensor_Pf 001 0887
Serial number: 3580000000017B111A16
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 6 - Part No SW: ----------- HW: 480 010 402 16
Component: SideSensor_Dr 004 0108
Serial number: 351001A05A82DE927F1K
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 7 - Part No SW: ----------- HW: 480 402 710 15
Component: FrontSensor_D 001 6149
Serial number: 3550002BD1D3F97611CL
Coding: 2D2D2D
Front Sensor Passenger:
Subsystem 8 - Part No SW: ----------- HW: 480 402 710 15
Component: FrontSensor_P 001 6149
Serial number: 3560002BF1D3F972710E
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 FH HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 16031608490598
Coding: A018
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 050010EB84D0CC6A93-8050
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 971 Q HW: 8V0 920 971 Q
Component: KOMBI H03 6423
Coding: 0BF410192B88D7050200E8001800000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009051
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 4B94E6D3E234FA1A05-801E
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 16031610802275
Coding: 0101000830085A005B00020C180B0000000101000000000000 0000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti.rod
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 08 03 2016 E0029375
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Component: Haldex4Motion H52 7083
Serial number: HA1-00018.02.16
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_VW48.rod
VCID: 4A9AE3D7ED4EE3123E-801E
Address 26: Auto Roof (J256) Labels: None
Part No SW: 8V7 959 255 HW: 8V7 959 255
Component: VSG-AU375 H03 0040
Coding: C00000
ASAM Dataset: EV_ElectRoofContrMAQAU37X 001005
ROD: EV_ElectRoofContrMAQAU37X.rod
VCID: 081E19DFB3C2D102E8-805C
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000049122009
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_VW37.rod
VCID: 34669D2F9FCA85E274-8060
Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H07 0080
Serial number: 0397916115
Coding: 030211
ASAM Dataset: EV_LaneChangAssis 001020
ROD: EV_LaneChangAssis_VW51.rod
VCID: 387EA91F83A2618258-806C
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: SWA Slave H07 0080
Serial number: 0392924147
Coding: 030211
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 210116EAG07588
Coding: 005D5B724008048000000402
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 C HW: 5Q0 959 812 C
Component: FOND_FHSG_DRV 002 0005
Serial number: 00000000000008762482
Coding: 110000
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 0102
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_VW37.rod
VCID: 4486CDEFCF6A3562C4-8010
Address 47: Sound System (J525) Labels: None
Part No SW: 8V0 035 465 D HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0420
Serial number: AUZ8ZAFN9021YC9
Coding: 01030800AA0A2AAA01
ASAM Dataset: EV_AMPMst16C3ALPI 001001
ROD: EV_AMPMst16C3ALPI.rod
VCID: 3978AC1BB8A8788AA7-806C
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 290116EAQ03903
Coding: 005D53724008048000000402
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 428ACBF7D57E3B52F6-8016
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 C HW: 5Q0 959 811 C
Component: FOND_FHSG_PSG 002 0005
Serial number: 00000000000008760984
Coding: 090000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0120
Revision: -------- Serial number: --------------
Coding: 012A000123200400
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
VCID: 3F8CC203A68C56BA99-806A
Led Headlamp Powermodule Left:
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E00100
Led Headlamp Powermodule Right:
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E00100
Left Headlamp Power Output Stage:
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo links H01 7050
Coding: E00100
Right Headlamp Power Output Stage:
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo rechts H01 7050
Coding: E00100
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8V0 035 038 C HW: 8V0 035 038 B
Component: MU-H-LNS-US H44 0403
Serial number: A302B0G7517477
Coding: 017305020000000021220002041A00102F000125010001047C
ASAM Dataset: EV_MUHig6C3HBAS 001040
ROD: EV_MUHig6C3HBAS_AU37.rod
Data medium:
Subsystem 1 - Part No SW: V03 959 800 TA HW: -----------
Component: NAR 2016/2017 --- 0054
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9FY2052P1
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: ALJAL119011600020123
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 3006
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 160
Mileage: 326 km
Date: 2016.06.17
Time: 08:21:57
Address 6C: Back-up Cam. (J772) Labels: 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_CamSysRearPANAAU914.rod
VCID: 306E913F6BD2B9C210-8064
End-------------------------(Elapsed Time: 04:48)--------------------------
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 160
Mileage: 326 km
Date: 2016.06.17
Time: 08:21:57
Ross-Tech: Home
5F 6C
Revision: --H13---
Coding: 0014
Coding: 030C0C
Coding: 0A47F7
Coding: 00006C
Light switch:
Alarm horn:
Coding: 0030150011
Coding: 333135
Coding: 333135
Occupant Detection:
Coding: 303333
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: A018
Alternator:
Coding: 0001
Coding: C00000
Coding: 030211
Coding: 030211
Coding: 110000
Coding: 0102
Coding: 090000
Coding: E00100
Coding: E00100
Coding: E00100
Coding: E00100
Data medium:
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 160
Mileage: 326 km
Date: 2016.06.17
Time: 08:21:57
It's not unusual for a sensor to report a fault incorrectly. I've had a couple for four years that never go away but the items reported work fine. since the car is under warranty, have the dealer check it out next time it's in. While it could be an intermittent issue, I'd bet it's just a glitchy report and the dealer will send you on your way. At least until something breaks.
BTW, no need to publish an entire scan - just those showing faults is good.
Audi4.2LV8
VAG-COM Discussion
04-06-2009 06:28 AM
