VAG-COM Discussion
Sponsored by:
Sponsored by:
Remote Key Windows/Sunroof VagCom
Old 04-26-2014, 08:07 PM
TheNit's Avatar
Default Remote Key Windows/Sunroof VagCom
I have a 2013 A6 2.0T and had my Audi mechanic put some mods in today (he just bought the unit out of his own money). One that didn't work as expected was the remote key operation of the windows/sunroof. He did the mod as follows [46-Cent Conv]-[coding-07]-[long coding helper] and changed byte 2, bits 2 and 3 from 0 to 1. I read elsewhere that once this is done you go into the MMI (Car-windows-windows conv open ...) and enable the functions. When I go into my MMI there is no option for Windows in the dropdown menu for Car. Is there another setting that has to be changed to get this to work?
I tried this post in the A6 section but no one has responded so I thought that I would try here.
Old 04-27-2014, 04:52 PM
2014Q5TDI's Avatar
Look inside the first menu item under cars. It is one menu deep. I did not see it at first either.
Old 04-27-2014, 06:41 PM
TheNit's Avatar
Wasn't there. The last item on the menu is Central Lock, nothing about windows at all. Do you need to reboot the MMI?
Old 04-28-2014, 03:45 AM
AudiQ5sleeper's Avatar
you will need to access the hidden green menu in order to allow the function to be seen
Old 04-29-2014, 12:46 PM
TheNit's Avatar
Nowhere else has it been stated that you need to enable the hidden menu. If I enable the hidden menu, what do I do at that point?
Old 05-01-2014, 05:49 PM
kgd_007's Avatar
Look inside the central locking menu. It should be in there on e enabled.
SloopJohnB@mac.com
A6 (C7 Platform) Discussion
14
07-16-2018 04:08 PM
jbgilbank
Q7 MK 1 Discussion
01-09-2018 11:44 AM
NR04
VAG-COM Discussion
11-07-2010 09:22 AM
SilverRing
12
04-13-2008 09:04 PM
lkeneston
VAG-COM Discussion
03-04-2007 06:24 PM
Quick Reply: Remote Key Windows/Sunroof VagCom
