Is this a coding problem?
Hi everyone!!
I have a 2006 Audi A6 C6 right hand drive. My mechanic recently-I think by mistake-changed some settings for the car. For starters, whenever I open the drivers' door, the small screen on the dash says that its the left passenger door that is open and when the left door is opened it indicates the right door. Secondly, the central locking switch on the drivers door stopped working and even the red light on it is off since then. Finally, the left side mirror stopped tilting when reversing despite the **** being in the left mirror position. We have tried everything using VCDS but we seem not to be able to remember where the settings were changed. Someone with an idea please HELP!!!
Cleo, someone in the UK could read their coding values and pass along to you.
I don't know if Ross-Tech might have a file for a UK vehicle they could send to you or at least provide guidance on restoring deault behaviours.
BTW, we can/should change your thread title to "UK-based" as we have many UK listeners here that could potentially provide assistance.
Welcome aboard!
Welcome aboard!
Tuesday,29,July,2014,10:00:03:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 36 37 42 46 47 4F 52
53 55 56 57 61 62 72 76
VIN: WAUZZZ4F16N183076 Mileage: 149200km/92708miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Sporadic communication error 1000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine (BDW) Labels: Redir Fail!
Part No SW: 4F0 910 552 R HW: 4F0 907 552 D
Component: 2.4l V6 MPI 0020
Revision: --H18--- Serial number:
Coding: 0105000402070120
Shop #: WSC 02325 785 00200
VCID: 32610411AD34409
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 4F1 910 155 F HW: 01J 927 156 JG
Component: V30 01J 2.4l 4V RdW 0050
Revision: --H06--- Serial number: 00000000000277
Coding: 0000001
Shop #: WSC 04940 001 00001
VCID: 2649E84191FC2C9
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
Component: ESP 8.0 front H05 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0021330
VCID: 2C5D1A698F10169
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0210
Revision: 27120501 Serial number: 10601000408186
Coding: 0000051
Shop #: WSC 02335 785 00200
VCID: E3CF3155224E191
Part No: 4F0 910 131 N
Component: FBSAUDIC6 EZS H45 0080
Part No: 4F0 910 220 B
Component: FBSAUDIC6 IDG H39 0060
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 730 P HW: 4E0 035 729 A
Component: Interfacebox H43 0830
Revision: 00000000 Serial number: 307CR067505379
Coding: 0000002
Shop #: WSC 00999 444 64523
VCID: 2E591061B90C649
Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H03 0050
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F2 820 043 J
Component: KLIMABETAETIGUNGH12 0170
Revision: 00000030 Serial number: 00000000256404
Coding: 0009286
VCID: DBBF09B51A3E211
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 C HW: 4F0 907 279 A
Component: ILM Fahrer H15 0190
Revision: 00000000 Serial number: 4F0907279
Coding: 0103101
VCID: 2953E37D80E2031
Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH12 0090
Coding: 00150573
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 C HW: 4E0 035 111
Component: CD-Changer H44 0340
Revision: 00000000 Serial number: AUZ5ZBF4032404
Shop #: WSC 00000 000 00000
VCID: 1933D3BDD082931
1 Fault Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 233
Mileage: 149008 km
Time Indication: 0
Date: 2014.07.23
Time: 17:36:36
Freeze Frame:
Text: 00000000
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4F AIRBAG AUDI8RH29 0280
Revision: 08H29000 Serial number: 0037LD0E4KVR
Coding: 0013382
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025061040101
Coding: 0112041
Shop #: WSC 02323 785 00200
VCID: E6C92841D17C6C9
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 931 A
Component: KOMBIINSTR. M73 H17 0660
Revision: 00200000 Serial number: 4PS31VZ36
Coding: 0000561
Shop #: WSC 01317 552 00000
VCID: 2143FB5DF8D2CB1
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 13008064058031
Coding: ECFE73CC3B2504
Shop #: WSC 02334 785 00200
VCID: 2757E54596F6351
1 Fault Found:
02077 - Media Player Position 2 (R119)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 233
Mileage: 149008 km
Time Indication: 0
Date: 2014.07.23
Time: 14:52:56
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 D HW: 4E0 035 785
Component: SG ext.Player H15 0830
Revision: 00000000
Coding: 010000
Shop #: WSC 02399 823 56573
VCID: 2953E37D40E2031
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0091138
VCID: E1C33B5D38520B1
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 H HW: 4E0 919 887 B
Component: MNS JP H04 0570
Revision: 0000005S Serial number: AUZBZ7F0102745
Part No: 4E1 910 336
Component: Interface Handy H08 0050
Part No: 4F0 919 813 A
Component: Card reader H02 0080
Part No: 4F0 035 503 B
Component: ETC-VICS-Ant. H01 0010
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: gQ
Coding: 0000016
Shop #: WSC 02327 785 00200
1 Fault Found:
02111 - Motor for Window Regulator
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 208
Mileage: 149207 km
Time Indication: 0
Date: 2014.07.29
Time: 09:34:49
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01012531890000
Coding: 0132493
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 A HW: 4F0 035 223 A
Component: DSP-High C6 H09 0140
Revision: PROD_01 Serial number: 00000000208684
Coding: 0000047
VCID: 1C3DCAA9DFB0E69
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000137327
Coding: 0001004
VCID: DEB900A1092C349
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00000000 Serial number: ‘CS
Coding: 0000016
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 A HW: 4F0 907 801
Component: EPB CA3C0040 H03 0040
Revision: --H03---
Coding: 0002033
Shop #: WSC 00000 785 00200
VCID: 1E39C0A1C9ACF49
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000016
VCID: 2855E6799BE83A9
Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 G HW: 4F0 035 541 C
Component: TUNER Japan H41 0170
Revision: 00000000 Serial number: 310DB067503154
Coding: 0000003
VCID: 244DF249E7C0DE9
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 E HW: 4E0 919 146 C
Component: TV analog TUNER H15 0270
Revision: 00000029 Serial number: 00000000034696
Coding: 0000016
VCID: 234FF155E2CED91
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000012121
Shop #: WSC 78800 981 54859
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2607030567
Coding: 344630393135313035442056413032363037303330353637
Shop #: WSC 07130 981 60669
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 F HW: 4F0 959 795 F
Component: TSG HL H21 0050
Coding: 0000002
VCID: 2F670D65BE066D1
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 F HW: 4F0 959 794 F
Component: TSG HR H21 0050
Coding: 0000016
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 E HW: 4F0 919 283 E
Component: Parkhilfe 8-Kan H12 0020
Revision: 00H12000 Serial number: 11820610004826
Coding: 0201006
Shop #: WSC 131071 1023 2097151
End ---------------------------------------------------------------------
Chassis Type: 4F0
Coding: 0000001
Coding: 0021330
Coding: 0000051
Coding: 0000002
Coding: 0009286
Coding: 0103101
Coding: 00062736
Shop #: WSC 02335
Coding: 00150573
Shop #: WSC 02335
1 Fault Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 233
Mileage: 149008 km
Time Indication: 0
Date: 2014.07.23
Time: 17:36:36
Freeze Frame:
Text: 00000000
Coding: 0013382
Coding: 0112041
Coding: 0000561
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 233
Mileage: 149008 km
Time Indication: 0
Date: 2014.07.23
Time: 14:52:56
Revision: 00000000
Coding: 010000
Coding: 0091138
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 208
Mileage: 149207 km
Time Indication: 0
Date: 2014.07.29
Time: 09:34:49
Coding: 0132493
Coding: 0000047
Coding: 0001004
Coding: 0000016
Revision: --H03---
Coding: 0002033
Coding: 0000016
Coding: 0000003
Coding: 0000016
Coding: 0000002
Coding: 0000016
Coding: 0201006
Change coding on module 17 to 0000461 for Great Britain.
The 5 it has now indicates Japan LHD.
Clear all DTCs, and see if that fixes the door lock issue and what if anything comes back.
Thanks a lot Jakematic, it worked perfectly!!!
Might you know if it is possible to update the MMI firmware with a disc from a different region? My MMI region is Japan but I have European CDs
Audi a6 2.4v6 1998 engine code AGA
Hello i wanted to ask if somebody got a label file .lbl and a .clb file for the engine code .AGA i cant adapt in vcds thankz for anyone that can help me greetz emil van straeten
