Cold Start Idle Air Control System Malfunction? - AudiWorld Forums
Old 07-07-2014, 08:57 PM   #1
Default Cold Start Idle Air Control System Malfunction?
Hey guys, I need your help figuring out exactly what this fault from the VagCom error log is referring to:
1 Fault Found:
001290 - Cold Start Idle Air Control System
P050A - 002 - Malfunction
The car shakes when cold starting and I have figured out (by process of elimination) that its not carbon cleaning or injectors. It behaves like a vacuum leak for the first 30sec that the car is on (if you pull out the oil dipstick while the car is on it will shake and hesitate like my car does when it turns on). The mechanic is not able to diagnose, so what do you guys think this error refers to?
thanks
turbotrip is offline   Reply With Quote
Old 07-08-2014, 05:21 AM   #2
jakematic's Avatar
A complete Auto-Scan would be more helpful, along with the year and model of the vehicle.
See also:
jakematic is offline   Reply With Quote
Old 07-11-2014, 09:13 AM   #3
DB22's Avatar
[QUOTE=jakematic;24584406]A complete Auto-Scan would be more helpful, along with the year and model of the vehicle.
QUOTE]
My guess is that it is one of the following:
1988 to 2015 Volkswagon, Audi, Seat or Skoda.
I really cannot work out which model though!
DB22 is offline   Reply With Quote
Old 07-11-2014, 09:48 AM   #4
jakematic's Avatar
This is a strong possibility, but I'm leaning to the Audi side
If I were a betting man I'd wager there are several other faults too...
Old 07-12-2014, 12:12 PM   #5
Sorry guys, its a 2009 Audi S5 4.2L V8
and there are some other errors but nothing that I'm concerned with. I just need to figure out what the hell this cold start idle air control system malfunction means as I'm sure this is the real problem with the car. Anyways here is the full report:
Quote:
Tuesday,11,June,2013,20:17:31:31949
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 8T0
Scan: 01 02 03 05 06 07 08 09 0E 0F 10 14 15 16 17 19 1B 1E 36 37
3C 42 46 47 52 53 55 56 67 6C 77
VIN: WAURV68T69A005833 Mileage: 110050km/68381miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1B-Active Steering -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAUB) Labels: 079-907-560-CAU.clb
Part No SW: 8T0 907 560 N HW: 8T0 907 560
Component: 4.2l V8/4V H10 0002
Revision: 76H10---
Coding: 01140009190F0120
Shop #: WSC 93204 999 85775
VCID: 4581802ACCDD2B3052A
1 Fault Found:
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Mileage: 110050 km
Time Indication: 0
Date: 2013.06.11
Time: 19:50:25
Freeze Frame:
RPM: 682 /min
Load: 77.2 %
Speed: 0.0 km/h
Temperature: 17.0C
Temperature: 21.0C
Absolute Pres.: 870.0 mbar
Voltage: 13.589 V
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
Part No SW: 8K0 927 158 B HW: 0B6 927 156
Component: 0B6 42 FSIUSA H04 0030
Revision: --H04---
Coding: 001002
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMAL651 A01001
ROD: EV_TCMAL651.rod
VCID: 3561F0EA943DBBB0C2A
No fault code found.
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AD HW: 8K0 907 379 AD
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 122500
VCID: 7BF526D2FA99ADC074E
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 AG HW: 8K0 907 064 AG
Component: BCM2 1.1 H71 0134
Revision: 00002001
Coding: 0D0000
VCID: 75E130EADCBDFBB002A
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
Address 06: Seat Mem. Pass (J521) Labels: 8T0-959-760.clb
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-BFS H09 0043
Revision: AA000000 Serial number: 00001003003850
Coding: 00017025002C00000000
VCID: 428B9B36DDF31C08778
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 M HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 340FP087507643
Coding: 0025003
VCID: 43859E3202E915007CE
Part No: 8T0 919 609 D
Component: E0380 BedienteilH08 0100
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0140
Revision: C1000000 Serial number: 0112.06.080335
Coding: 48022000
VCID: 72EB0BF6ADD3EC88278
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000063496
Coding: 26001096463CAF311F00080300003D3D0F9CD3C80001016100 0000
VCID: 306FC1FE635F9E9891C
Subsystem 1 - Part No SW: 8T1 955 119 C HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 280608 H13 0040
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 J HW: 8K0 941 531 J
Component: E1 - LDS H07 0070
Subsystem 4 - Part No SW: 8K0 907 410 A HW: 8K0 907 410 A
Component: UGDO HL US H04 0060
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T1 035 110 C HW: 8T1 035 110 C
Component: MP3-Changer H42 0390
Revision: 00042002 Serial number: AUZ5ZBH8443423
Shop #: WSC 00000 000 00000
VCID: 2A5BD3968583E4485F8
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7H0350139
Coding: 0000102
VCID: 3169C4FAA85597909E2
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 3
Reset counter: 79
Mileage: 106290 km
Time Indication: 0
Date: 2008.02.11
Time: 01:51:37
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 D HW: 8K0 919 475
Component: PARKHILFE 4K H06 0020
Revision: 11001001 Serial number: 52930816301116
Coding: 200102
VCID: 3A7BE3D6B52354C82F8
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8K0 907 364 HW: 8K0 907 364
Component: DAEMPFUNGS-SG H08 0052
Revision: 00000000 Serial number: 30050802210003
Coding: 050181
Shop #: WSC 93030 999 50402
VCID: F0EF81FE23DF5E9851C
2 Faults Found:
01769 - Sensor for Vehicle Leveling; Front Right (G289)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 103851 km
Time Indication: 0
Date: 2012.10.24
Time: 14:43:33
Freeze Frame:
03262 - Comfort Restriction
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 234
Mileage: 103851 km
Time Indication: 0
Date: 2012.10.24
Time: 14:43:34
Freeze Frame:
Error Code: 2
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 C HW: 8K0 959 655 C
Component: AirbagVW-AU10 H26 0410
Serial number: 0039GD1255V%
Coding: 30413333373030303030554A304C38543053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3D71E8CAAC0D63F00AA
Crash sensor for side airbag; driver side:
Serial number: 6334MSME32034E3EG
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME3B320D219
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME74511B7BO
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME74473E65S
Crash sensor for front airbag; driver side:
Serial number: 63732SME79231B61$
Crash sensor for front airbag; passenger side:
Serial number: 63832SME7C311C597
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90315HFH000BO
Coding: 000036
VCID: 3E73EFC6A90B78E8130
Component: E221 - MFL H02 0003
2 Faults Found:
01426 - Controls in Steering Wheel (E221)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 106405 km
Time Indication: 0
Date: 2013.02.13
Time: 21:30:38
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 40
Mileage: 1048575 km
Time Indication: 0
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 931 B HW: 8T0 920 931 B
Component: KOMBIINSTR. H30 0221
Revision: 00000000 Serial number: 97N51GU68
Coding: 8B0701003A000008020000
VCID: 3663F7E6813BB0A8CB0
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 L HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0092
Revision: FB402044 Serial number: 4400F08527808C
Coding: 000303
VCID: 4A9BB316E5C3C448BF8
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 B HW: 8K0 907 144 B
Component: DYNAMIKLENK. H05 0490
Revision: 50000003 Serial number: --------------
Coding: 840000
Shop #: WSC 06324 000 00000
VCID: 2E53DF86796B8868830
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
Coding: 020000
VCID: 2B55D6924A79FD40A4E
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Component: MEM-FS H09 0043
Revision: AA000000 Serial number: 00001003004990
Coding: 00197B25002C00000000
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H51 1100
Revision: 00000000 Serial number: 341FO087509513
Shop #: WSC 93030 999 59315
VCID: 387FF9DE4B2F46D8D9C
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 8K0 907 566 B HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0050
Revision: 00H01000 Serial number: 6PZ 009 014-13
Coding: 0000004
VCID: 3663F7E6413BB0A8CB0
Part No: 8K0 907 568 B
Component: J0770_SWA_Slave_H01 0040
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 HW: 8K0 959 793
Component: TSG FA H09 0149
Revision: Serial number: Q
Coding: 011C13224E002201
VCID: FDF1A8CA648D23F0CAA
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0112483774
Coding: 0106029A007A440500B000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 M HW: 8T0 035 223 C
Component: DSP Prem H12 0280
Revision: 00H12003 Serial number: 34813000393402
Coding: 020101
Shop #: WSC 12336 024 394758
VCID: 387FF9DE8B2F46D8D9C
7 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 85
Mileage: 106482 km
Time Indication: 0
Date: 2013.02.15
Time: 14:43:56
Freeze Frame:
Voltage: 12.30 V
Temperature: 38.0C
Temperature: 41.0C
Bin. Bits: 00000100
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 2
Time Indication: 0
Date: 2000.00.00
Time: 00:02:23
Freeze Frame:
Voltage: 11.90 V
Temperature: 31.0C
Temperature: 32.0C
Bin. Bits: 00000100
00875 - Treble Speaker Front Right (R22)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 245
Mileage: 103914 km
Time Indication: 0
Date: 2012.11.08
Time: 12:34:47
Freeze Frame:
Voltage: 11.90 V
Temperature: 30.0C
Temperature: 35.0C
Bin. Bits: 00000100
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 245
Mileage: 103914 km
Time Indication: 0
Date: 2012.11.08
Time: 12:34:47
Freeze Frame:
Voltage: 11.90 V
Temperature: 30.0C
Temperature: 35.0C
Bin. Bits: 00000100
00420 - Right Front DSP Midrange Speaker (R104)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Time Indication: 0
Date: 2000.00.00
Time: 00:02:23
Freeze Frame:
Voltage: 11.90 V
Temperature: 31.0C
Temperature: 32.0C
Bin. Bits: 00000100
02559 - Right Rear Mid-Range/Woofer Loudspeaker (R160)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Time Indication: 0
Date: 2000.00.00
Time: 00:02:23
Freeze Frame:
Voltage: 11.90 V
Temperature: 31.0C
Temperature: 32.0C
Bin. Bits: 00000100
00422 - Right Rear DSP Midrange Speaker (R106)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Time Indication: 0
Date: 2000.00.00
Time: 00:02:23
Freeze Frame:
Voltage: 11.90 V
Temperature: 31.0C
Temperature: 32.0C
Bin. Bits: 00000100
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 HW: 8K0 959 792
Component: TSG BF H09 0149
Revision: Serial number: $3
VCID: FCF7A5CE7F972AF8FD4
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 126
Reset counter: 233
Mileage: 108301 km
Time Indication: 0
Date: 2013.04.25
Time: 08:08:26
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 10000000050187
VCID: 3169C4FA685597909E2
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 8
Reset counter: 84
Mileage: 106276 km
Time Indication: 0
Date: 2013.01.23
Time: 13:56:11
Freeze Frame:
Voltage: 7.40 V
Count: 44
Hex Value: 0x0160
Hex Value: 0x0088
Hex Value: 0x0101
Address 55: Xenon Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 A HW: 8H0 907 357
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 306FC1FEA35F9E9891C
Part No: 7L6 941 329 A
Component: AFS-Modul links H07 0004
Component: AFS-Modul rechtsH07 0004
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 00110010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 106332 km
Time Indication: 0
Date: 2008.02.18
Time: 01:41:27
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 N
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 357FX087505717
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 123
Reset counter: 17
Mileage: 106276 km
Time Indication: 0
Date: 2013.01.23
Time: 13:35:26
End ---------------------------------------------------------------------
Old 07-12-2014, 12:25 PM   #6
jakematic's Avatar
Quote:
I'm a bit concerned with the voltage situation on those freeze frames.
Has the battery been replaced, gone flat, etc ?
Code:
Is this Auto-Scan really that old ?
If so the first thing to do is clear all DTCs, drive for awhile, and scan again.
Also you should first update to version 12.12.2
Unfortunately I do not have an answer for you on the 001290, but someone else may.
Old 07-13-2014, 08:17 PM   #7
that was actually right after the battery had been replaced...
and yes the scan is from last year, but i had cleared the errors twice and gotten the same error, so im sure that is the recurring problem.
and unfortunately i dont have a vagcom cable now to do a current scan
Thread Thread Starter Forum Replies Last Post
Audi A6 FS: 370mm Alcon / Stasis Front Big Brake Kit! Allroad BBK N'Syncro Parts For Sale 12 01-24-2017 03:46 PM
:: ECS Tuning :: NEW!! B8 A4 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi A4 (B8 Platform) Discussion 14 12-23-2016 03:46 AM
Frustrated 2004 Audi A8L 4.2L jeffkruse A8 / S8 (D3 Platform) Discussion 5 09-04-2015 11:59 AM
:: ECS Tuning :: NEW!! B7 A4 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi A4 (B7 Platform) Discussion 0 09-01-2015 09:16 AM
:: ECS Tuning :: NEW!! B8 A5 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-01-2015 08:27 AM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
