VAG-COM Discussion
Sponsored by:
Sponsored by:
Confused by TPMS code, anyone help?
Old 05-08-2012, 06:49 PM
K9COP's Avatar
Default Confused by TPMS code, anyone help?
Hi guys, this may be slightly duplicitous, but I want to get my TPMS working correctly. The status quo is:
Car (2005 A8 4.2 shorty) has aftermarket 20" R8 rims on it, old (19" turbine) spare. The spare still has Sensor in it, the four rims do not, as I had them built up without as the VCDS says it couldn't reach the controller.
I'm happy to replace all five with new orange, but can I test them/the receiver(s?) without installing everything?
I've always had a TPMS icon on the dash. Autoscan results repeated below, always the same address 65 result..
I want to end up with an error free car, but first, TPMS working...
thanks, K9
Tuesday,24,April,2012,14:11:05:40451
VCDS Version: Release 11.11.3 (x64)
Data version: 20120401
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAULL44E35N015651 Mileage: 232110km/144226miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Cannot be reached 1100
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 J HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E1759901
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2855C9C39BE83A9
1 Fault Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 S HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0020
Revision: --H01--- Serial number: 0054165
Coding: 0000002
VCID: 32612BABAD34409
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 2241DBEBFDD4D09
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 D
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0E1759901
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8B539036B08CA9
Part No: 4E0 905 852 D
Component: ELV 1834
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: 234FDEEFE2CED91
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 G HW: 4E0 035 729
Component: Interfacebox H43 1070
Revision: 00000000 Serial number: 346BD057520412
Coding: 0000000
Shop #: WSC 00000 000 00000
VCID: 244DDDF3E7C0DE9
Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
3 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 21
Mileage: 230076 km
Time Indication: 0
Date: 2012.03.13
Time: 19:01:13
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 71
Mileage: 231989 km
Time Indication: 0
Date: 2012.04.21
Time: 08:38:45
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 1
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000062155
Coding: 1052993
VCID: 1C3DE513DFB0E69
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No HW: 4E0 907 279 L
Component: RLS NO RESPONSE
Coding: 0123123
VCID: 55ABB037FC1A771
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000036
Shop #: WSC 02313
2 Faults Found:
02510 - Steering Column Adjustment
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 21
Reset counter: 11
Mileage: 0 km
Time Indication: 0
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 96
Reset counter: 7
Mileage: 0 km
Time Indication: 0
Address 0E: Media Player 1
Cannot be reached
Address 0F: Digital Radio Labels:
Part No: 4E0 910 593 B
VCID: 2649C7FB91FC2C9
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
2 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
002 - Lower Limit Exceeded - MIL ON
01587 - Igniter 2 for Airbag; Drivers Side (N250)
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012241
VCID: E5CB00F72C7A671
Part No: XXXXXXXXXXX
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 G HW: 4E0 920 950 G
Component: KOMBIINSTR. VDO H53 0210
Revision: D05 Serial number: AUDID3E1004444
Coding: 0016233
Shop #: WSC 08126 444 85715
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H10 0080
Revision: 10 Serial number: 1900305217004F
Coding: FCFE7BDD1B7904
VCID: 2757CAFF96F6351
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 76
Mileage: 230076 km
Time Indication: 0
Date: 2012.03.13
Time: 18:55:42
02076 - Media Player Position 1 (R118)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 237
Reset counter: 76
Mileage: 230076 km
Time Indication: 0
Date: 2012.03.13
Time: 18:56:38
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 5
Reset counter: 115
Mileage: 230483 km
Time Indication: 0
Date: 2012.03.21
Time: 15:21:38
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV 1834
4E0905852D ELV 1834
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0011310
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 C HW: 4E0 919 887 C
Component: MNS US H44 0960
Revision: 00000000 Serial number: 378B-057517397
VCID: 2E593FDBB90C649
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000433500111
Coding: 0003477
VCID: 1D3BE817C4AAEF1
1 Fault Found:
02153 - Sunroof Button (E325); Close
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 88
Mileage: 231136 km
Time Indication: 0
Date: 2012.04.07
Time: 07:29:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM002 0060
Coding: 0028204
VCID: 2045D1E3F3D8C29
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040503010007
Coding: 0065086
Part No: 4E0 910 853
Component: Heckdeckel H06 0050
Part No: 4E0 907 719
Component: Neigungssensor H03 0020
1 Fault Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Reset counter: 75
Mileage: 155710 km
Time Indication: 0
Date: 2008.07.29
Time: 18:42:25
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000011673
Coding: 0000016
VCID: 254BC0F7ECFA271
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000056576
Coding: 0010111
VCID: 1E39EF1BC9ACF49
Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM002 0060
Coding: 0028204
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000532
Shop #: WSC 08126 444 83438
VCID: 1F47D21FCEA6FD1
2 Faults Found:
02442 - Function Lamp in Control Head
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 6
Fault Frequency: 171
Reset counter: 116
Mileage: 230112 km
Time Indication: 0
Date: 2012.03.14
Time: 18:05:00
Freeze Frame:
Voltage: 12.84 V
Count: 65
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 247
Time Indication: 0
Freeze Frame:
Voltage: 9.52 V
Count: 61
Address 55: Xenon Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000001
VCID: E2C11BEB3D54109
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396CP057505073
Coding: 0000002
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000001930
Shop #: WSC 08126 444 00568
Subsystem 1 - Part No: 4E0 910 181 C
Component: von VA0 0000000204
Coding: 344530393130313831432056413030303030303030323034
Shop #: WSC 12345 128 00289
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 29
Reset counter: 116
Mileage: 230196 km
Time Indication: 0
Date: 2012.03.16
Time: 04:18:01
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0028204
Address 65: Tire Pressure
Cannot be reached
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000502180131
Shop #: WSC 12336 024 394758
VCID: 346D2DB357204E9
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0028204
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08720504000144
Coding: 0001208
VCID: 2143D4E7F8D2CB1
2 Faults Found:
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 116
Mileage: 230837 km
Time Indication: 0
Date: 2012.04.02
Time: 14:05:46
01629 - Sensor for Parking-Aid; Front Left (G255)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 21
Mileage: 230076 km
Time Indication: 0
Date: 2012.03.14
Time: 13:53:26
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 A HW: 4E0 862 335
Component: Handyvorb2 H10 0120
Coding: 0010900
Part No: 4F0 910 336 A
No Faults Found
or DTCs not supported by controller
or a communication error occurred
End ---------------------------------------------------------------------
Old 05-10-2012, 10:08 AM
Dana @ Ross-Tech's Avatar
You will need to get the Tire Pressure Monitoring module (J502) online and communicating. Please check the repair manual but it looks like that unit is located under the rear seat - so I'd make sure it is plugged in and has the necessary powers/grounds.
Old 05-11-2012, 05:57 PM
K9COP's Avatar
Default Thanks Dana,
I've located the unit under the rear seat and it appears to be all plugged in and grounded appropriately. I'll get sensors replaced in all five wheels and see where we go from there.
Thanks, K9
pcamaj
13
03-01-2011 10:01 AM
Kahuna-Big
VAG-COM Discussion
12-08-2009 07:08 AM
Jack Wang
VAG-COM Discussion
02-19-2007 04:16 AM
AudiRX
VAG-COM Discussion
01-25-2007 01:37 PM
srs
VAG-COM Discussion
10-26-2003 08:48 PM
Quick Reply: Confused by TPMS code, anyone help?
