Crank no start
Crank no start
My wife was driving yesterday and all of a sudden it just quit. She ran the battery dead trying to get it restarted and listening to the radio waiting for the tow truck to arrive. I vag-scanned it and logged the info to post here for help. I scanned it two times saving each scan and deleting both to see if any dtc's would come back. I have what appears as both cam sensors G40 and G163 both reappearing after a delete and retry. Is it possible both can go bad at the same time, I have doubts. Please help. I have included some of the Dtc's from the 1st and 2nd scans.
Wednesday,19,March,2008,08:59:34:39539
VAG-COM Version: Release 704.1
Data version: 20071016
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 078-907-551-AZA.LBL
Part No: 8D0 907 551 A
Component: 310 1V6/5VT G 0002
Coding: 06611
Shop #: WSC 01551
10 Faults Found:
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
P0421 - 35-10 - - - Intermittent
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
P1296 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 35-10 - - - Intermittent
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
P1454 - 35-10 - - - Intermittent
16815 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
P0431 - 35-10 - - - Intermittent
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-10 - - - Intermittent
17746 - Camshaft Position Sensor (G40): Open or Short to Plus
P1338 - 35-00 - -
17800 - Camshaft Position Sensor Bank 2 (G163): Open Short to Plus
P1392 - 35-00 - -
Readiness: 0000 0000
Wednesday,19,March,2008,14:37:23:39539
Coding: 06611
Shop #: WSC 01551
2 Faults Found:
P1392 - 35-00 - -
P1338 - 35-00 - -
Readiness: 0110 0101
Address 08: Auto HVAC Labels: None
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D57
Coding: 00160
Shop #: WSC 06325
No fault code found.
Address 15: Airbags Labels: 8D0-959-655-AI8.LBL
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 06325
2 Faults Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Coding: 06611
Shop #: WSC 01551
10 Faults Found:
P1606 - 35-00 - -
P1338 - 35-00 - -
P1392 - 35-00 - -
Coding: 06611
Shop #: WSC 01551
2 Faults Found:
P1392 - 35-00 - -
P1338 - 35-00 - -
Coding: 00160
Shop #: WSC 06325
Coding: 00304
Shop #: WSC 06325
2 Faults Found:
Clear the codes, see which ones reoccur. ...
The camshaft sensors, are suspect, but the crankshaft speed/position sensor output must exist or the engine will quit, and won't restart. Check the crankshaft speed sensor.
Ok, still no luck
I replaced the RPM sensor and decided to replace the fuel pump relay but I still can't get it started. I am very puzzled. I went so far as to check the air-fuel-spark, just to see if all those systems individually would work. They all did. I erased the DTC's, cranked it again and got both cam sensors. I've included reports for reference. Please shed some light. I will say that I did get the most codes today while I was checking for air-fuel and spark together which did not return after I erased and rescanned.
Wednesday,26,March,2008,15:45:10:39539
Coding: 06611
Shop #: WSC 01551
11 Faults Found:
P1392 - 35-00 - -
P1338 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-10 - - - Intermittent
17880 - EVAP Leak Detection Pump: Short to Ground
P1472 - 35-10 - - - Intermittent
17938 - Camshaft Timing Adjustment: Short to Ground
P1530 - 35-10 - - - Intermittent
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 35-10 - - - Intermittent
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 35-10 - - - Intermittent
17529 - Oxygen (Lambda) Sensor Heating Circuit: B2 S2: Short to Ground
P1121 - 35-10 - - - Intermittent
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-10 - - - Intermittent
17908 - Fuel Pump Relay (J17): Electrical Malfunction
P1500 - 35-10 - - - Intermittent
Coding: 00160
Shop #: WSC 06325
Coding: 00304
Shop #: WSC 06325
2 Faults Found:
Address 17: Instruments Labels: 8D0-920-xxx-17.LBL
Part No: 8D0 920 980 D
Component: B5-KOMBIINSTR. VDO D11
Coding: 02264
Shop #: WSC 00000
1 Fault Found:
00771 - Fuel Level Sensor (G)
30-10 - Open or Short to Plus - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16140
Shop #: WSC 06325
Address 45: Inter. Monitor Labels: 4B0-951-173.LBL
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06325
Address 55: Xenon Range Labels: 4B0-907-357-AUT.LBL
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 06325
Address 56: Radio Labels: 8D0-035-1xx-56.LBL
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00201
Shop #: WSC 01013
End --------------------------------------------------------------------------------------------------
Wednesday,26,March,2008,17:25:58:39539
Coding: 06611
Shop #: WSC 01551
2 Faults Found:
P1392 - 35-00 - -
P1338 - 35-00 - -
Coding: 00160
Shop #: WSC 06325
Coding: 00304
Shop #: WSC 06325
2 Faults Found:
Coding: 02264
Shop #: WSC 00000
Coding: 00101
Shop #: WSC 06325
Coding: 00012
Shop #: WSC 06325
Coding: 00201
Shop #: WSC 01013
Wednesday,26,March,2008,17:42:08:39539
Coding: 06611
Shop #: WSC 01551
3 Faults Found:
P1392 - 35-00 - -
P1338 - 35-00 - -
P0571 - 35-00 - -
Coding: 00160
Shop #: WSC 06325
Coding: 00304
Shop #: WSC 06325
2 Faults Found:
Coding: 02264
Shop #: WSC 00000
Coding: 16140
Shop #: WSC 06325
Coding: 00101
Shop #: WSC 06325
Coding: 00012
Shop #: WSC 06325
Coding: 00201
Shop #: WSC 01013
1 Fault Found:
00-00 - -
Wednesday,26,March,2008,18:14:42:39539
Coding: 06611
Shop #: WSC 01551
2 Faults Found:
P1392 - 35-00 - -
P1338 - 35-00 - -
Coding: 00160
Shop #: WSC 06325
Coding: 00304
Shop #: WSC 06325
2 Faults Found:
Coding: 02264
Shop #: WSC 00000
Coding: 16140
Shop #: WSC 06325
Coding: 00101
Shop #: WSC 06325
Coding: 00012
Shop #: WSC 06325
Coding: 00201
Shop #: WSC 01013
Coding: 06611
Shop #: WSC 01551
11 Faults Found:
P1392 - 35-00 - -
P1338 - 35-00 - -
Coding: 00160
Shop #: WSC 06325
Coding: 00304
Shop #: WSC 06325
2 Faults Found:
Coding: 02264
Shop #: WSC 00000
1 Fault Found:
Coding: 16140
Shop #: WSC 06325
Coding: 00101
Shop #: WSC 06325
Coding: 00012
Shop #: WSC 06325
Coding: 00201
Shop #: WSC 01013
Coding: 06611
Shop #: WSC 01551
2 Faults Found:
P1392 - 35-00 - -
P1338 - 35-00 - -
Coding: 00160
Shop #: WSC 06325
Coding: 00304
Shop #: WSC 06325
2 Faults Found:
Coding: 02264
Shop #: WSC 00000
Coding: 00101
Shop #: WSC 06325
Coding: 00012
Shop #: WSC 06325
Coding: 00201
Shop #: WSC 01013
Coding: 06611
Shop #: WSC 01551
3 Faults Found:
P1392 - 35-00 - -
P1338 - 35-00 - -
P0571 - 35-00 - -
Coding: 00160
Shop #: WSC 06325
Coding: 00304
Shop #: WSC 06325
2 Faults Found:
Coding: 02264
Shop #: WSC 00000
Coding: 16140
Shop #: WSC 06325
Coding: 00101
Shop #: WSC 06325
Coding: 00012
Shop #: WSC 06325
Coding: 00201
Shop #: WSC 01013
1 Fault Found:
00-00 - -
Coding: 06611
Shop #: WSC 01551
2 Faults Found:
P1392 - 35-00 - -
P1338 - 35-00 - -
Coding: 00160
Shop #: WSC 06325
Coding: 00304
Shop #: WSC 06325
2 Faults Found:
Coding: 02264
Shop #: WSC 00000
Coding: 16140
Shop #: WSC 06325
Coding: 00101
Shop #: WSC 06325
Coding: 00012
Shop #: WSC 06325
Coding: 00201
Shop #: WSC 01013
Check for water in the ECU box! ...
What common mode/cause could be involved with the DTCs that reoccur? Besides the cam sensors, the fuel pump relay DTC is a clue. Note that all those systems are present in the ECU box. If there is spark, correctly timed, and the correct fuel/air ratio, the engine will start. Maybe the engine is flooded from before.
I checked the ecu box....
and there is no water or moisture. Its dry as a bone and the seals appear to be ok between ecu and harness. Like I said before I replaced the main fuel relay with a new one just for good measure. I haven't pulled the plugs and checked for flooding. I would assume only from looking at other posts that the timing would have to be correct otherwise I should see a plausability dtc. I must say that I did only get the fuel pump relay code while I was running the air/fuel/spark test. I am not sure why. I disconected the fuel return and ran a hose into an empty water bottle and cranked it a few revolutions to check for fuel. It just doesn't make any sense to me.
cutchemist42
06-07-2013 04:19 AM
myers1.8TQ
09-22-2008 02:52 AM
NYImola::NYMisano
04-25-2008 06:33 AM
Nogaro Stg3
06-10-2006 08:24 AM
