Default ABS Coding - A3 3.2VR6
Hi, All:
I've searched high and low, and unfortunately, I somehow either didn't preserve my default coding for the ABS module or mucked it up somehow.
Using the VCDS documentation (waiting on my account on the Ross Tech forum to be activated) and several web resources, I'm attempting to enable the Passive TPMS on my 2006 A3 S-Line with 18" wheels and the MK60 ABS controller. I followed the excellent tutorial at OOOO-A3's weblog, but the thing that's missing in the engine coding value to sum the correct value for my 3.2l VR6-equipped car.
With the 2.0l four, the default passive TPMS coding is 0021122, but when I enter that value minus the 0016384 (new coding 0004738) to enable passive TPMS, my TPMS light simply flashes. I'm pretty convinced at this point that the coding value for my engine must be wrong, giving me the wrong starting point for the coding.
I've verified the MK60 ABS unit, brake code, and suspension type on my PR sticker; how do I find the default coding for the 3.2l VR6 to sum the correct coding that will enable my passive TPMS?
Code:
Tuesday,09,December,2014,12:51:44:42699 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 14.10.0.0 Data version: 20141022 VIN: WAUKD78P36A083401 License Plate: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8P (8L - Audi A3/S3 (1997 > 2003)) Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76 VIN: WAUKD78P36A083401 Mileage: 172560km-107223miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 022-906-032-BDB.lbl Part No SW: 022 906 032 GP HW: 000 000 000 00 Component: MOTRONIC ME7.1.1G 8192 Revision: --H01--- Serial number: AUX7Z0E9FN60S8 Coding: 0000178 Shop #: WSC 06314 000 00000 VCID: 5FCD8BAC8D9B57D9361-5122 2 Faults Found: 049441 - No Communication with ABS Brake Control Module U0121 - 008 - - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 164577 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 79.0∞C Temperature: 62.0∞C Absolute Pres.: 1000.0 mbar Voltage: 11.938 V 049441 - No Communication with ABS Brake Control Module U0121 - 008 - - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 164577 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 79.0∞C Temperature: 62.0∞C Absolute Pres.: 1000.0 mbar Voltage: 11.938 V Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-927-770.lbl Part No SW: 02E 300 047 A HW: 02E 927 770 AD Component: GSG DSG 070 1002 Revision: 04507000 Serial number: 00000509071118 Coding: 0000020 Shop #: WSC 06314 000 00000 VCID: 1623EE8821215691A57-8043 1 Fault Found: 18259 - Powertrain Data Bus P1851 - 000 - Missing Message from ABS Controller - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 255 Reset counter: 23 Mileage: 164577 km Time Indication: 0 Date: 2014.11.20 Time: 16:29:03 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-614-517-MK60-A.lbl Part No SW: 1K0 614 517 S HW: 1K0 614 517 S Component: ESP 4MOTION MK60-AT 0102 Revision: 00T12001 Coding: 0021122 Shop #: WSC 06314 000 00000 VCID: 377D030C46EB4F999E1-8062 1 Fault Found: 01042 - Control Module; Not Coded 000 - - - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8P0-820-043.lbl Part No SW: 8P0 820 043 L HW: 8P0 820 043 L Component: KlimavollautomatH17 0200 Revision: 021822 Serial number: 8P0820043L Shop #: WSC 06314 000 00000 VCID: 356109045CE7BD898CD-8060 1 Fault Found: 01301 - Control Module for Voice Recognition (J507) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 16 Reset counter: 48 Mileage: 155995 km Time Indication: 0 Date: 2014.03.10 Time: 17:52:40 Freeze Frame: ON ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8P0-959-655-94.lbl Part No SW: 8P0 959 655 A HW: 8P0 959 655 A Component: Airbag 9.41 H12 3770 Revision: 91H12377 Serial number: 0035W000918F Coding: 0432605 Shop #: WSC 06314 000 00000 VCID: 408F68D0132508212FB-8015 Subsystem 1 - Part No: 8P0 910 339 Component: BF-Gewichtsens. 001 0020 Subsystem 2 - Serial number: 35MB2 Subsystem 3 - Serial number: 0001.01.000000100000000000ˇÜ63 Subsystem 4 - Serial number: 000000ˇÜ6332DRB401F5549F.ˇÜ63 Subsystem 5 - Serial number: 5549F.ˇÜ6342DRB401F4C80D.ˇÜ63 Subsystem 6 - Serial number: 4C80D.ˇÜ63528RB4009E17DBZˇÜ63 Subsystem 7 - Serial number: E17DBZˇÜ63628RB4009E16BBXˇÜ63 Subsystem 8 - Serial number: E16BBXˇÜ63729RB400BD2A62RˇÜ63 Subsystem 9 - Serial number: D2A62RˇÜ63829RB400BD2A0FZˇ Subsystem 10 - Serial number: D2A0FZˇ 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 44 Mileage: 164577 km Time Indication: 0 Date: 2014.11.20 Time: 16:29:03 ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8P0-953-549-F.lbl Part No SW: 8P0 953 549 F HW: 8P0 953 549 F Component: J0527 H34 0070 Coding: 0014142 Shop #: WSC 06314 000 00000 VCID: 41896DD4182F0129205-8014 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H07 0080 1 Fault Found: 01301 - Control Module for Voice Recognition (J507) 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl Part No SW: 8P0 920 981 EX HW: 8P0 920 981 EX Component: KOMBIINSTR. VDO H80 0460 Revision: D09 Serial number: 224NGD09100017 Coding: 0000204 Shop #: WSC 50096 000 1048576 VCID: 122B92980DC94AB1C9F-8047 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: 1K0-907-554.lbl Part No: 1K0 907 554 B Component: HALDEX 4Motion 0107 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 2C572C608FADFC41E33-8079 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 E HW: 4F0 907 357 E Component: AFS 1 H01 0010 Revision: 00000001 Serial number: Coding: 0000020 Shop #: WSC 06314 000 00000 VCID: 285FD0709B55D06107B-807D Subsystem 1 - Part No: 8E0 941 329 A Component: AFS-Modul links H03 0010 Subsystem 2 - Part No: 8E0 941 329 A Component: AFS-Modul rechtsH03 0010 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 40 Mileage: 164584 km Time Indication: 0 Date: 2014.11.20 Time: 16:29:03 ------------------------------------------------------------------------------- Address 56: Radio Labels: 8P0-035-1xx-56.lbl Part No SW: 8P0 035 195 K HW: 8P0 035 195 K Component: symphony II US H51 0460 Revision: 04S Serial number: AUZ5Z4E6102587 Coding: 0522241 Shop #: WSC 65337 005 00000 VCID: 3A7B1A3875F952F161F-806F 1 Fault Found: 01301 - Control Module for Voice Recognition (J507) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 6 Reset counter: 48 Mileage: 163493 km Time Indication: 0 Date: 2014.11.09 Time: 09:09:39 End-------------------------(Elapsed Time: 03:27)-------------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: DTCs cleared -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 02: DTCs cleared
audilogue
VAG-COM Discussion
12-15-2005 01:59 PM
algisas
Audi 100 / A6 (C4 Platform)
11-21-2005 07:45 AM
Ok, have the VAG hooked up to my car with the ABS light on. Can't connect at all with the ABS proble
S4Del
12-12-2003 04:23 PM
