Default Coding for 2014 A4 (B8) Cent Elect and Insturments
I've posted this at Ross Tech and Audizine with no response so I'm reposting here. Sorry if anyone has already seen this.
I did do a couple of quick searches in this thread as well with no luck.
Just purchased a new 2014 A4 and am looking at changing a bunch of the settings. Right now the default coding for Central Elect and Insturments seems puzzling.
The default coding for the 09- Cent. Elect. is here
Code:
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DF HW: 8K0 907 063 DF
Component: BCM1 1.0 H16 0103
Revision: 06016001 Serial number: 00000063196602
Coding: 26000096863CAFC00000480300003D0D0F1C13082209020100 0004004400030100000000000000
Shop #: WSC 02391 785 00200
VCID: 76E90CE8C17525AEB1B-8023
Subsystem 1 - Part No SW: 8K1 955 119 B HW: 8K1 955 119 B
Component: MITSUBA170214 H18 0461
Coding: 004577
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Here the default coding does not have the Rain/Light Sensor (G397) installed but the car does have the rain/light sensor and both seem to work fine.
Similarly the 17-Instruments coding seems even more suspect
Code:
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 901 K HW: 8K0 920 901 K
Component: KOMBIINSTR. H09 0564
Revision: 00200000 Serial number: Z9Y65UW2F
Coding: 8B84090002010008020000
VCID: 336FF5FC92877086565-8066
Specifically here [17 - Instruments] - Byte 1 - Bit 4 isn't set (i.e. Washer Fluid Warning is not active), Byte 5 - Bit 0 is set (Adaptive Air Suspension Installed) and Byte 10 - Bit 0 is not set (Brake Pad Wear Warning is not active).
These are basically the opposite of what I'd expect. I'm most surprised by the Air Suspension bit as I'd expect this to be giving me errors of some sort and if I actually uncheck the Adaptive Air Suspension Installed I actually get a coding error.
Are the descriptions basically reversed for these items? Has anyone verified the setting?
Thanks for your help.
Shawn
Code:
Coding: 004577
Coding: 02005D
Code:
Shawn
newb2audi
VAG-COM Discussion
01-24-2013 11:32 AM
OA 69
06-15-2007 06:27 PM
