Does this mean that the switch is bad, or that something is triggering it? Vag scan inside
Monday,25,August,2008,20:54:35:57405
VCDS Version: Release 805.1
Address 08: Auto HVAC
Control Module Part Number: 8D0 820 043 N
Component and/or Version: A4 KLIMAAUTOMAT D53
Software Coding: 00160
Work Shop Code: WSC 06335
Fault Codes have been Erased
1 Fault Found:
2 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
My A/C doesn't work, and I'd like it to. Could it be as simple as replacing the saftey switch?
1 Fault Found:
Yes, I think bad switch
What year is it? What engine? Yes it looks like the switch is bad. You can test the switch with an ohm meter, and you can remove the switch without discharging the system. I have gone to a wrecking yard and removed a switch for pennies and have fixed this problem.
Hillbilly
08-26-2008 05:40 PM
rhuTTchp
Audi 100 / A6 (C4 Platform)
9
03-09-2008 04:58 PM
