DTCs
DTCs
Hello all,
I have codes 16502: Engine Coolant Temp. Sensor (Signal to high) and 17704: Error in mapped coding system (usually temp sensor or thermostat).
Does anyone know the reason for these codes? All help is appreciated!!
I can help you with 16502 ...dont know about 17704 though
For 16502 this indicates a bad coolant temp sensor.
Before you go out and buy one, clear the code and retest to make sure it was not a mistake.
If the DTC is thrown consistently then get a new coolant temp sensor and O-ring. The sensor is located at the rear of the engine( between the engine block and the firewall.)
Time for a Coolant Temp Sensor..
Will probably fix both codes.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
~DonQPremiumTequila~
06-11-2008 09:22 AM
mtmOla'
VAG-COM Discussion
10-22-2004 05:48 PM
zeems
03-01-2004 05:21 PM
absentme
10-10-2002 07:05 PM
