engine codes please help
Can someone explain the codes on my car?
I also noticed a white smoke from the exhaust.
Address 01: Engine Labels: 058-907-55x-AEB2.lbl
Part No: 8D0 907 557 S
Component: 1,8L R4/5V MOTR AT D03
Coding: 02031
Shop #: WSC 06335
VCID: 40855ED94098E29
6 Faults Found:
16518 - Oxygen (Lambda) Sensor B1 S1
P0134 - 35-10 - No Activity - Intermittent
17972 - Throttle Actuator (J338)
P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
00561 - Mixture Adaptation
12-10 - Adaptation Limit (Mul) Exceeded - Intermittent
17916 - Idle Control Sys
P1508 - 35-10 - Upper Regulation Limit Reached - Intermittent
16500 - Engine Coolant Temp. Sensor (G62)
P0116 - 35-10 - Implausible Signal - Intermittent
Readiness: N/A
Coding: 02031
Shop #: WSC 06335
6 Faults Found:
P1570 - 35-00 -
Readiness: N/A
englsh
08-08-2007 11:53 AM
