Engine mount Solenoid and misfire
The issues started with a random battrey drain, It would be dead and then start up again later then I got an ECL, See the Vag Com read out below. Where do I start?
6 Faults Found:
17979 - Left Engine Mount Solenoid Valve (N144)
P1571 - 001 - Short to Plus
16405 - Bank 2: Camshaft A (Intake)
P0021 - 008 - Retard Setpoint not Reached (Over-Advanced) - MIL ON
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
16689 - Cylinder 5
P0305 - 001 - Misfire Detected - MIL ON
16690 - Cylinder 6
P0306 - 001 - Misfire Detected - MIL ON
16691 - Cylinder 7
P0307 - 008 - Misfire Detected - MIL ON
Readiness: 0000 0000
Address 01: Engine Labels:
Control Module Part Number:
Component and/or Version:
Software Coding:
Work Shop Code:
VCID: 55AF8A57AC7CD1B022A
6 Faults Found:
16689 - Cylinder 5
16690 - Cylinder 6
16691 - Cylinder 7
Readiness: N/A
Saturday,18,May,2013,09:34:55:32135
VCDS Version: Release 11.11.5
Data version: 20121222
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Control Module Part Number: 8E0 907 279 F
Component and/or Version: int. Lastmodul USA 0517
Software Coding: 01013
Work Shop Code: WSC 63351
VCID: 356F2AD70F3CF1B0C2A
1 Fault Found:
02104 - Light Detection Sensor (G399)
29-10 - Short to Ground - Intermittent
6 Faults Found:
16689 - Cylinder 5
16690 - Cylinder 6
16691 - Cylinder 7
Software Coding:
Work Shop Code:
6 Faults Found:
16689 - Cylinder 5
16690 - Cylinder 6
16691 - Cylinder 7
Readiness: N/A
1 Fault Found:
