Fault code: 00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
What's this VAG code all about? I've only found 1 thread that leads me to believe it's the clutch??
Any help of diagnosing?
Here's the official log:
VAG-COM Version: Release 704.1
Data version: 20071016
Monday,05,May,2008,13:08:39:11955
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAULC68E12A313253 Mileage: 87150km/54152miles
Address 01: Engine Labels: 06B-909-518-AMB.LBL
Part No SW: 8E0 909 518 F HW: 8E0 909 018
Component: 1.8L R4/5VT G 0001
Coding: 0016701
Shop #: WSC 13109
No fault code found.
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04275
Shop #: WSC 06435
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Part No: 8E0 820 043 Q
Component: A4 Klimaautomat 1015
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
30-10 - Open or Short to Plus - Intermittent
69 75 76 77
Coding: 0016701
Shop #: WSC 13109
Coding: 04275
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
It is regarding the servo motor position feedback sensor associated with the ....
HVAC system Air Recirculaton flap in the HVAC housing. Specifically, the wiring to/from the feedback sensor is either "open circuit, or the sensor signal return wire is shorted to the sensor +voltage supply wire.
Garrett's S4
VAG-COM Discussion
02-07-2009 07:03 AM
joeycuccaro
NY / NJ / CT Discussion
11-11-2008 08:43 AM
