Fault CODE HELP
Fault CODE HELP
2000 A6 2.7T
Symptom :
When driver door is little ajar, interior light won't come on and won't display "door ajar" in the cluster.
And Memory seat is not working either
Help me plz
Thanks
Here are fault codes
Thursday,20,April,2006,13:34:52
VAG-COM Version: Release 512.1-UD
Control Module Part Number: 4B0 962 258 J
Component and/or Version: Central Lock/Alarm D32
Software Coding: 15981
Work Shop Code: WSC 05211
7 Faults Found:
00668 - Supply Voltage Terminal 30
07-10 - Signal too Low - Intermittent
00991 - Interior Lights
28-10 - Short to Plus - Intermittent
01566 - Activate Signal for Interior Monitor
01568 - Signal for Convenience Opening
00952 - Signal; Drivers Door Open
01571 - Signal for Seat Memory
29-10 - Short to Ground - Intermittent
01357 - Tank Flap Locking Motor (V155)
29-00 - Short to Ground
Symptom :
Help me plz
Thanks
7 Faults Found:
my suggestion.....and I'm really not trying to be an ***....
you have three choices to grapple with:
1) bring the car to someone with Audi/diagnostic/electrical experience (1-2 day fix)
2) call someone you know with the above experience and hang with him/her and learn (1-30 day fix)
3) start teaching yourself the above experience, and fix your own car (7-365 day fix, or possibly never)
Trying to talk someone through basic wiring diagram reading, multimeter functions, and test light procedures, while at the same time, trying to diagnose a fault via a forum interface will take days and weeks.
A6w2.7T
04-20-2006 10:44 AM
