Fault Code Removal
Fault Code Removal
Fault clearing ?
2009 , S-line, multitronic.
I blew the 35A fuse that feeds the drivers side elec windows . I have renewed the fuse, cleared the fault codes but still have the one below. (03157 - Functionality limited due to Communications Disruption)
Does this mean that something wants re-coding as it won't clear?
Sunday,05,May,2013,15:20:43:31033
VCDS Version: Release 11.11.5
Data version: 20121222
Address 5F: Information Electr. Labels: 4E0-035-6xx-5F.clb
Control Module Part Number: 4E0 035 652 A HW: 4E0 035 652
Component and/or Version: B-BN-EU H47 0048
Software Coding: 010101010102C3FD43000F0DEF7300030001
Work Shop Code: WSC 00779 210 97010
VCID: 1F47CC660EC4E5E0386
1 Fault Found:
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 247
Mileage: 55676 km
Time Indication: 0
Date: 2013.05.05
Time: 15:13:56
Freeze Frame:
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00000101
I went into 5F - then 02 codes - showed 1 fault - erase codes, the fault code was erased but reappeared.
I will drive it tomorrow and try it again.
This was done with ignition on, engine off.
This was the readout after I replaced the fuse & befor deleating the fault codes.
Now all removed apart from 5F (in bold red)
09 is OK - I have removed the fuse for the headlight washers.
Sunday,05,May,2013,14:33:50:31033
Chassis Type: 4F0
Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56 5F
62 72 76
VIN: WAUZZZ4F19N036857 Mileage: 55670km/34591miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine (CAN) Labels: Redir Fail!
Part No SW: 4F7 910 401 K HW: 4F0 907 401 E
Component: 2.7TDI EDC17G000CG 0090
Revision: 16H01--- Serial number:
Coding: 010D002C02070128
Shop #: WSC 18432 423 592680
VCID: 2B5F28B68A7C0940A4E
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 4F5 910 157 H HW: 01J 927 156 JG
Component: V30 0AN 2.7lTDI RdW 0010
Revision: --H05--- Serial number: 00000000000328
Coding: 0000001
Shop #: WSC 02325 785 00200
VCID: 2E5921A2B96E7C68830
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AK HW: 4F0 614 517 AT
Component: ESP8 front H03 0060
Revision: 00000000 Serial number: 00000000000000
Coding: 0020876
VCID: 6DDBE6AE74E8C770FAA
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 B HW: 4F0 905 852 D
Component: FBSAUDIC6 ELV H05 0100
Revision: 00H05000 Serial number: 10602601261827
Coding: 0000147
Shop #: WSC 02324 785 00200
VCID: 254BDE8EEC983F3072A
Part No: 4F0 910 132 E
Component: FBSAUDIC6 EZS H03 0020
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 B HW: 4F2 820 043 AA
Component: KLIMABETAETIGUNGH30 0070
Revision: 00000073 Serial number: 00000000601444
Coding: 0001302
VCID: 1D3BF66EC4C8F7F02AA
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 N HW: 4F0 907 279
Component: ILM Fahrer H22 0320
Revision: 00000000 Serial number: 4F0907279
Coding: 0013121
Shop #: WSC 02335 785 00200
VCID: 346D33CA574256B8F54
Subsystem 1 - Part No: 4F2 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H10 0040
Coding: 00056595
Shop #: WSC 02335
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00146221
Shop #: WSC 02335
4 Faults Found:
00456 - Control Module for Access and Start Control (J518)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 30
Mileage: 55608 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:00
00061 - Footwell Lights
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00110111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Mileage: 55608 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:00
00910 - Indicator Lamp for Emergency Flashers (K6)
Freeze Frame:
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 55608 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:00
00924 - Relay for Headlamp Cleaning System (J39)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 247
Mileage: 55608 km
Time Indication: 0
Date: 2013.05.03
Time: 10:40:00
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 L HW: 4E0 035 110 A
Component: CDC-MP3-Pana H47 0050
Revision: 00000012
VCID: 2143CA9E38B0D3100E2
Address 15: Airbags (J234) Labels: 4F0-910-655-10.clb
Part No SW: 4F0 910 655 L HW: 4F0 959 655 E
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 30314236303630303033554A305234463053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 30653FDA6B5A6A9891C
Crash sensor for side airbag; driver side:
Serial number: 3574SRB400008495215.
Crash sensor for side airbag; passenger side:
Serial number: 3584SRB40000849D397E
Crash sensor for side airbag; rear driver side:
Serial number: 35152RB402J838NMVR2V
Crash sensor for side airbag; rear passenger side:
Serial number: 35252RB402P838NMV35H
Crash sensor for front airbag; driver side:
Serial number: 3554NRB40000491848A/
Crash sensor for front airbag; passenger side:
Serial number: 3564NRB4000049100D8W
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0530
Revision: 00H05000 Serial number: 90055083440101
Coding: 0102142
VCID: 2757D48696942D20406
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 29
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:10
Address 17: Instruments (J285) Labels: 4F0-920-xxx-17.clb
Part No SW: 4F0 920 983 B HW: 4F0 920 983 B
Component: KOMBIINSTR. H06 0135
Revision: 00000000 Serial number: AE940E1D8
Coding: 2F56110502002600010400
Shop #: WSC 02391 823 56573
VCID: 2B5F28B64A7C0940A4E
Address 19: CAN (J533) Labels: 4F0-907-468.clb
Part No SW: 4F0 907 468 F HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0024
Revision: 4LA70021 Serial number: 2100L0910680F4
Coding: 000303
VCID: 326135D26D565888E78
Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
Component: J367-BDM H07 0107
Address 42: Door Elect, Driver (J386) Labels: 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000100632175
Coding: 011F06205041410001
VCID: 46897902F1DED4285B0
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:41:53
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:41:54
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01166766660000
Coding: 0140027
VCID: 31633ADEA85063909E2
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 29
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:18
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 035 223 P HW: 4F0 035 223 P
Component: BOSE G3 C6 H01 0100
Revision: AG001300 Serial number: 00000000002161
Coding: 0F010000
VCID: 2953D2BE40801B50562
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H13 0100
Revision: Serial number: 00000000610073
Coding: 0001103
Shop #: WSC 02145 785 00200
VCID: DEB93162094E2CE8F30
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 30
Mileage: 55608 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:00
Freeze Frame:
Voltage: 12.200 V
Temperature: 77.0°C
Address 52: Door Elect, Pass. (J387) Labels: 4F0-959-792.clb
Part No SW: 4F0 959 792 R HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000100622308
VCID: 458B7E0ECCD8DF3052A
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 30
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:17
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Mileage: 1048575 km
Time Indication: 0
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 D HW: 4F0 907 801 B
Component: EPB CEFC0090 H05 0090
Revision: --H05---
Coding: 0000531
VCID: 2143CA9EF8B0D3100E2
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000003
VCID: 3F876CE66E0485E0186
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 053 B HW: 4F0 035 053
Component: Radio U Basic H44 0020
Revision: AB001007 Serial number: 341AQ097529712
Coding: 010003010000000000
VCID: 1C3DFB6A1FD2FEF8DD4
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4E0 035 652 A HW: 4E0 035 652
Component: B-BN-EU H47 0048
Revision: -------- Serial number: 349A-097506098
Shop #: WSC 00779 210 97010
Subsystem 1 - Part No SW: 4L0 919 604 HW: 4L0 919 604
Component: DU6 Basic H43 0306
Subsystem 2 - Part No SW: 4F0 910 609 E HW: 4F2 919 611 H
Component: Bedienteil MM H01 0060
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 245
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:43:13
Freeze Frame:
02259 - Information Display and Control Head (Front) (J685)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 30
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:53:47
Freeze Frame:
Voltage: 12.30 V
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 M HW: 8K0 959 795 B
Component: TSG HL H10 0251
Revision: Serial number: 0000100645651
Coding: 010E04204041220001
VCID: 438F6016C2ECE1007CE
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100645097
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:43:31
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:43:32
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4L0 910 283 A HW: 4L0 919 283 A
Component: Parkhilfe 8-Kan H02 0400
Revision: 00H02000 Serial number: 13630901502908
Coding: 0201016
VCID: 2855D7BA9B8A225849C
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 30
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:09
End ---------------------------------------------------------------------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 0E: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 42: DTCs cleared
Address 46: DTCs cleared
Address 47: DTCs cleared
Address 4F: DTCs cleared
Address 52: DTCs cleared
Address 53: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
Address 5F: DTCs cleared
Address 62: DTCs cleared
Address 72: DTCs cleared
Address 76: DTCs cleared
Chassis Type: 4F0
62 72 76
Readiness: 0 0 0 0 1
Coding: 0000001
Coding: 0020876
Coding: 0000147
Coding: 0001302
Coding: 0013121
Coding: 00056595
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
Revision: 00000012
Coding: 0102142
Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
Coding: 000303
Coding: 0140027
Coding: 0F010000
Coding: 0001103
Revision: --H05---
Coding: 0000531
Coding: 0000003
Coding: 0201016
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 247
Mileage: 55676 km
Time Indication: 0
Date: 2013.05.05
Time: 15:13:56
Freeze Frame:
Chassis Type: 4F0
62 72 76
Coding: 0000001
Coding: 0020876
Coding: 0000147
Coding: 0001302
Coding: 0013121
Coding: 00056595
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 30
Mileage: 55608 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Mileage: 55608 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 55608 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:00
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 247
Mileage: 55608 km
Time Indication: 0
Date: 2013.05.03
Time: 10:40:00
Revision: 00000012
Coding: 0102142
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 29
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:10
Coding: 000303
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:41:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:41:54
Coding: 0140027
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 29
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:18
Coding: 0F010000
Coding: 0001103
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 30
Mileage: 55608 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:00
Freeze Frame:
Voltage: 12.200 V
Temperature: 77.0°C
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 30
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:17
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Mileage: 1048575 km
Time Indication: 0
Revision: --H05---
Coding: 0000531
Coding: 0000003
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 245
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:43:13
Freeze Frame:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 30
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:53:47
Freeze Frame:
Voltage: 12.30 V
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:43:31
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:43:32
Coding: 0201016
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 30
Mileage: 55609 km
Time Indication: 0
Date: 2013.05.03
Time: 10:54:09
Chassis Type: 4F0
62 72 76
Coding: 0000001
Coding: 0020876
Coding: 0000147
Coding: 0001302
Coding: 0013121
Coding: 00056595
Shop #: WSC 02335
Coding: 00146221
Shop #: WSC 02335
Revision: 00000012
Coding: 0102142
Coding: 000303
Coding: 0140027
Coding: 0F010000
Coding: 0001103
Revision: --H05---
Coding: 0000531
Coding: 0000003
Coding: 0201016
